Ir para o conteúdo principal
Hipstreet Equinox 2 Motherboard Replacement
O que você precisa
  1. Hipstreet Equinox 2 Motherboard Replacement, Rear Case: passo 1, imagem 1 %32
    • Remove the two 3mm screws using a PH00 screwdriver.
  2. Hipstreet Equinox 2 Motherboard Replacement: passo 2, imagem 1 %32
    • Use the blue plastic opening tool to gently pry the back case off.
  3. Hipstreet Equinox 2 Motherboard Replacement, Motherboard: passo 3, imagem 1 %32
    • Unsolder these wires from the motherboard, it is a good idea to label these wires as you remove them according to the picture to the left.
  4. Hipstreet Equinox 2 Motherboard Replacement: passo 4, imagem 1 %32
    • Remove contact strips by lifting gently on the clip indicated in this picture, then pulling strip out of the clip.
  5. Hipstreet Equinox 2 Motherboard Replacement: passo 5, imagem 1 %32
    • Remove the 3.5mm screws located at these locations shown on the picture by using the PH00 screwdriver.
  6. Hipstreet Equinox 2 Motherboard Replacement: passo 6, imagem 1 %32
    • Gently lift the motherboard out of the tablet, make sure no wires are still caught or attached while you lift the motherboard.
Conclusão
Brandon Snodgrass
Membro desde: 01/29/15
410 Reputação
Autoria de 4 guias
Equipe
Clemson, Team 15-8, Shirley Winter 2015 Membro de Clemson, Team 15-8, Shirley Winter 2015
CLEM-SHIRLEY-W15S15G8
Membros da 5
Autoria de 12 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 0
Duração total: 381
