Ir para o conteúdo principal
Heyday Suitcase Turntable Needle Replacement
  1. Heyday Suitcase Turntable Needle Replacement, Needle: passo 1, imagem 1 %32 Heyday Suitcase Turntable Needle Replacement, Needle: passo 1, imagem 2 %32
    • Before you begin the repair, turn off the record player and unplug the power cord.
    • Remove cartridge lock by pushing inwards (towards the needle arm, while lightly squeezing the sides by hand. Then pull downwards and towards you to disengage the locking hook. This will unhook the lock between cartridge and base.
    Pergunte ao FixBot
    Comentar
  2. Heyday Suitcase Turntable Needle Replacement: passo 2, imagem 1 %32
    • Disconnect the wires from the cartridge.
    Pergunte ao FixBot
    Comentar
Conclusão
To reassemble your device, follow these instructions in reverse order. Replace the needle by clipping it back onto the cartridge and then reconnect the wires to the correct part of the cartridge.
Caroline D'Amato
Membro desde: 10/26/22
565 Reputação
Autoria de 6 guias
Equipe
UMass Dartmouth, Team 2-1, Petersen Fall 2022 Membro de UMass Dartmouth, Team 2-1, Petersen Fall 2022
UMASSD-PETERSEN-F22S2G1
4 Membros
Autoria de 7 guias
0Comentários do guia
Comentar
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 5
Últimos 30 dias: 38
Ao todo: 1,113
