Ir para o conteúdo principal
Havoc Heli IR LED Replacement
O que você precisa
  1. Havoc Heli IR LED  Replacement, Havoc Heli IR LED: passo 1, imagem 1 %32 Havoc Heli IR LED  Replacement, Havoc Heli IR LED: passo 1, imagem 2 %32
    • Power off the controller before disassembly.
    • Place a small piece of tape over the Light button to prevent it from falling out in later steps.
    • Flip the controller over so the back is facing up.
    Pergunte ao FixBot
    Comentar
  2. Havoc Heli IR LED  Replacement: passo 2, imagem 1 %32 Havoc Heli IR LED  Replacement: passo 2, imagem 2 %32 Havoc Heli IR LED  Replacement: passo 2, imagem 3 %32
    • Remove the battery compartment screw with a small Phillips screw driver.
    • Lift off the battery cover.
    • Remove the six AA batteries from the compartment.
    Pergunte ao FixBot
    Comentar
  3. Havoc Heli IR LED  Replacement: passo 3, imagem 1 %32 Havoc Heli IR LED  Replacement: passo 3, imagem 2 %32 Havoc Heli IR LED  Replacement: passo 3, imagem 3 %32
    • Remove the remaining four screws with a small Phillips screw driver.
    • Flip the device over so the front is facing up.
    • Remove the front cover and place it to the left side.
    • Make sure to note the locations of the joysticks and other controls in case they fall out of place during this or future steps.
    Pergunte ao FixBot
    Comentar
  4. Havoc Heli IR LED  Replacement: passo 4, imagem 1 %32
    • Lift up the red IR LED cover to remove it.
    Pergunte ao FixBot
    Comentar
  5. Havoc Heli IR LED  Replacement: passo 5, imagem 1 %32 Havoc Heli IR LED  Replacement: passo 5, imagem 2 %32
    • Use the soldering iron and solder wick to remove the solder from the IR LED you're replacing.
    • Pull the LED out through the top.
    Pergunte ao FixBot
    Comentar
  6. Havoc Heli IR LED  Replacement: passo 6, imagem 1 %32 Havoc Heli IR LED  Replacement: passo 6, imagem 2 %32
    • Insert the new LED into the slot.
    • Make sure that the short lead of the LED is on the right.
    • Use the soldering iron and solder to connect the new LED.
    Pergunte ao FixBot
    Comentar
Conclusão
Uma outra pessoa concluiu este guia.
Michael Kent
Membro desde: 03/30/16
128 Reputação
Autoria de 1 guia
Equipe
Michigan Tech, Team 1-13, Lauer Fall 2016 Membro de Michigan Tech, Team 1-13, Lauer Fall 2016
MTU-LAUER-F16S1G13
1 Membro
Autoria de 2 guias
0Comentários do guia
Comentar
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 5
Últimos 30 dias: 41
Ao todo: 997
