Ir para o conteúdo principal
Hasbro Iron Man Infinity Nano Gauntlet Speaker Replacement
O que você precisa
  1. Hasbro Iron Man Infinity Nano Gauntlet Speaker Replacement, Speaker: passo 1, imagem 1 %32
    • Find the location of the damaged speaker. The speaker can be located above the battery pack on the forearm.
    • Find the damaged wire. It must be replaced with a new one.
  2. Hasbro Iron Man Infinity Nano Gauntlet Speaker Replacement: passo 2, imagem 1 %32 Hasbro Iron Man Infinity Nano Gauntlet Speaker Replacement: passo 2, imagem 2 %32
    • Desolder the damaged wire from the speaker and replace it with a new one.
    • It will be beneficial to use the wire stripping tool in order to do this.
  3. Hasbro Iron Man Infinity Nano Gauntlet Speaker Replacement: passo 3, imagem 1 %32
    • Once the new wire is attached to the speaker, it must then be reattached to the circuit board.
    • Once the new wires are securely placed in the correct spot, the hand can be put back together.
Conclusão
Tori Mariano
Membro desde: 02/24/23
347 Reputação
Autoria de 1 guia
Equipe
Marist, Team 1-3, Chaterdon Spring 2023 Membro de Marist, Team 1-3, Chaterdon Spring 2023
MARS-CHATERDON-S23S1G3
3 Membros
Autoria de 6 guias
0Comentários do guia
Comentar
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 12
Últimos 30 dias: 41
Ao todo: 325
