Ir para o conteúdo principal
Hard Reset
  1. Hard Reset, Hard Reset: passo 1, imagem 1 %32
    • With the phone powered off, press and hold the Talk/Send, End, and Power buttons (the 3 circled here) for about 3 seconds.
    Pergunte ao FixBot
    Comentar
  2. Hard Reset: passo 2, imagem 1 %32 Hard Reset: passo 2, imagem 2 %32
    • When the screen powers on, you will see an instructional message.
    • Press the volume up button to perform the hard reset.
    • The hard reset will erase all personal data on your device. If you would like to cancel the hard reset, press any other button.
    Pergunte ao FixBot
    Comentar
  3. Hard Reset: passo 3, imagem 1 %32
    • Your device will display this screen after a few seconds. Press the Volume Up button to boot your phone.
    Pergunte ao FixBot
    Comentar
  4. Hard Reset: passo 4, imagem 1 %32 Hard Reset: passo 4, imagem 2 %32
    • Your phone will display this screen. If you would like to import your SIM contacts now, tap "Import SIM contacts" and tap "Next". Otherwise, tap "Cancel".
    Pergunte ao FixBot
    Comentar
Conclusão
You have just performed a hard reset on your HTC Fortress. All personal data on your phone has been deleted, and your phone is now back to its default settings.
7 outras pessoas executaram este guia.
Lucas David
Membro desde: 04/19/13
540 Reputação
Autoria de 9 guias
Equipe
Cal Poly, Team 4-13, Maness Spring 2013 Membro de Cal Poly, Team 4-13, Maness Spring 2013
CPSU-MANESS-S13S4G13
4 Membros
Autoria de 22 guias
1Comentário do guia
great information thanks.
regards
Jrubio - Responder Compartilhar
Comentar
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 15
Últimos 30 dias: 47
Ao todo: 2,884
