Ir para o conteúdo principal
Hard / Factory Reset
Vídeo de Apresentação
  1. Hard / Factory Reset, Hard Reset - Method One:: passo 1, imagem 1 %32 Hard / Factory Reset, Hard Reset - Method One:: passo 1, imagem 2 %32 Hard / Factory Reset, Hard Reset - Method One:: passo 1, imagem 3 %32
    • Switch off the phone.
    • Pres the Power button and when you feel a vibration release it and press and hold the Volume Up button.
    • From Boot mode menu select [Recovery mode] (use Volume Up for navigation and volume doun for OK).
    • Now you are in the known Android System recovery menu. Use again the Volume Up for navigation and the Volume Down for OK and select one by one: wipe data/factory reset - Yes -- delete all user data - reboot system now.
    • Tis will reboot the device and will restore to its default settings.
    Pergunte ao FixBot
    Comentar
  2. Hard / Factory Reset, Factory Reset - Method Two: passo 2, imagem 1 %32 Hard / Factory Reset, Factory Reset - Method Two: passo 2, imagem 2 %32 Hard / Factory Reset, Factory Reset - Method Two: passo 2, imagem 3 %32
    • Press the Power button and wen you fill the vibration, release the Power button and press and hold the Volume Down button.
    • Now the device is in Factory mode. Use the Volume Up/Down buttons for movement and the Power button for OK and select Clear eMMC.
    • That's all. The phone will reboot and will be restored to a factory settings.
    • Did you do it successfully?
    Pergunte ao FixBot
    Comentar
Conclusão
28 outras pessoas executaram este guia.
ZFix
Membro desde: 12/09/13
197.270 Reputação
Autoria de 330 guias
Equipe
Master Techs Membro de Master Techs
Community
334 Membros
Autoria de 1.701 guias
22Comentários do guia
great simple clear instructions - did exactly what you said - phone back up and running good as new! Thanks. M
Marty - Responder Compartilhar
Thanks. The phone has reset.
melandart - Responder Compartilhar
“eMMC is busy can't format, please retry”
What do we do?
richterrea - Responder Compartilhar
Today I also met this message. How did you solve this problem? Thanks, Zoltan (HUN)
Zoltán Bocskai - Responder Compartilhar
HI!, I did the “clear eMMc” method but still my MePop_V03 phone still stock on logo screen.
what should I do?
Please help me .thanks in advance God bless
Herbert Redondo - Responder Compartilhar
Comentar
Visualizações:
Últimas 24 horas: 14
Últimos 7 dias: 71
Últimos 30 dias: 355
Ao todo: 56,238
