Ir para o conteúdo principal
Hannspree Hannspad SN1AT71 Wi-Fi Card Replacement
O que você precisa
  1. Hannspree Hannspad SN1AT71 Wi-Fi Card Replacement, Back Panel: passo 1, imagem 1 %32
    • Place the tablet screen side up.
    • Make sure the device is turned off to avoid damage.
  2. Hannspree Hannspad SN1AT71 Wi-Fi Card Replacement: passo 2, imagem 1 %32 Hannspree Hannspad SN1AT71 Wi-Fi Card Replacement: passo 2, imagem 2 %32
    • Use the metal spudger to press an opening between the screen and back cover.
    • The plastic tabs are located on each corner of the back cover.
    • Be careful, as the plastic tabs are delicate.
  3. Hannspree Hannspad SN1AT71 Wi-Fi Card Replacement: passo 3, imagem 1 %32
    • Wedge the plastic opening tool between the screen and the back panel to prevent re-engagement
  4. Hannspree Hannspad SN1AT71 Wi-Fi Card Replacement: passo 4, imagem 1 %32 Hannspree Hannspad SN1AT71 Wi-Fi Card Replacement: passo 4, imagem 2 %32
    • Slide the metal spudger around the casing to separate it from the inside of the tablet.
  5. Hannspree Hannspad SN1AT71 Wi-Fi Card Replacement: passo 5, imagem 1 %32 Hannspree Hannspad SN1AT71 Wi-Fi Card Replacement: passo 5, imagem 2 %32
    • Flip the tablet over so the screen side is down after all the tabs are separated.
    • Remove the back panel by delicately lifting it straight up.
  6. Hannspree Hannspad SN1AT71 Wi-Fi Card Replacement, Battery: passo 6, imagem 1 %32 Hannspree Hannspad SN1AT71 Wi-Fi Card Replacement, Battery: passo 6, imagem 2 %32
    • Remove the adhesive tape from the power connection cables.
  7. Hannspree Hannspad SN1AT71 Wi-Fi Card Replacement: passo 7, imagem 1 %32 Hannspree Hannspad SN1AT71 Wi-Fi Card Replacement: passo 7, imagem 2 %32 Hannspree Hannspad SN1AT71 Wi-Fi Card Replacement: passo 7, imagem 3 %32
    Ferramenta utilizada nesse passo:
    Comprar
    • Instructions for desoldering can be found on the iFixit website.
    • The soldering iron is hot. It can burn you and it can cause damage to the wires and motherboard.
    • Grab hold of the red wire using the tweezers.
    • Desolder the red wire connection from the motherboard using the tip of the soldering iron.
    • Move the wire connection away from the motherboard.
    • Do not let the red wire connection touch other wires or the motherboard.
  8. Hannspree Hannspad SN1AT71 Wi-Fi Card Replacement: passo 8, imagem 1 %32 Hannspree Hannspad SN1AT71 Wi-Fi Card Replacement: passo 8, imagem 2 %32 Hannspree Hannspad SN1AT71 Wi-Fi Card Replacement: passo 8, imagem 3 %32
    • Desolder the black and yellow wire connection from the motherboard by following the previous step.
    • When moving the wire connections, do not let the red wire connection touch other wires or the motherboard.
  9. Hannspree Hannspad SN1AT71 Wi-Fi Card Replacement: passo 9, imagem 1 %32 Hannspree Hannspad SN1AT71 Wi-Fi Card Replacement: passo 9, imagem 2 %32 Hannspree Hannspad SN1AT71 Wi-Fi Card Replacement: passo 9, imagem 3 %32
    • Insert the flat end of the nylon spudger between the battery and the case.
    • The battery is connected to the tablet with an adhesive tape and will come free slowly.
    • Do not puncture or bend the battery while removing. If your battery is swollen, take appropriate precautions.
  10. Hannspree Hannspad SN1AT71 Wi-Fi Card Replacement, Wi-Fi Card Replacement: passo 10, imagem 1 %32
    • Identify the card and its connection to the motherboard.
    • The card itself.
    • The area where the card connects to the motherboard.
  11. Hannspree Hannspad SN1AT71 Wi-Fi Card Replacement: passo 11, imagem 1 %32 Hannspree Hannspad SN1AT71 Wi-Fi Card Replacement: passo 11, imagem 2 %32 Hannspree Hannspad SN1AT71 Wi-Fi Card Replacement: passo 11, imagem 3 %32
    • Peel off the adhesive tape holding the wires down.
  12. Hannspree Hannspad SN1AT71 Wi-Fi Card Replacement: passo 12, imagem 1 %32 Hannspree Hannspad SN1AT71 Wi-Fi Card Replacement: passo 12, imagem 2 %32
    • Desolder the wire.
  13. Hannspree Hannspad SN1AT71 Wi-Fi Card Replacement: passo 13, imagem 1 %32 Hannspree Hannspad SN1AT71 Wi-Fi Card Replacement: passo 13, imagem 2 %32
    Comprar
    • Use the tweezers to peel the Wi-Fi card off.
Conclusão
Uma outra pessoa concluiu este guia.
Equipe
Colorado Springs, Team 9-4, Panko Spring 2015 Membro de Colorado Springs, Team 9-4, Panko Spring 2015
UCCS-PANKO-S15S9G4
Membros da 3
Autoria de 10 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 4
Últimos 30 dias: 10
Duração total: 710
