Ir para o conteúdo principal
Hamilton G5 Ventilation Unit Motherboard Replacement
Equipamento Médico
Nem o iFixit nem este guia de reparo são endossados ou afiliados ao fabricante do dispositivo médico.
O que você precisa
  1. Hamilton G5 Ventilation Unit Motherboard Replacement, Rail: passo 1, imagem 1 %32
    • Remove 4 Hex Allen screws (A) from the Rail surrounding the Ventilation Unit.
    Pergunte ao FixBot
    Comentar
  2. Hamilton G5 Ventilation Unit Motherboard Replacement: passo 2, imagem 1 %32
    • Remove the Rail (B).
    Pergunte ao FixBot
    Comentar
  3. Hamilton G5 Ventilation Unit Motherboard Replacement: passo 3, imagem 1 %32
    • The Standoff Brackets (C) remain with the Main Cover.
    Pergunte ao FixBot
    Comentar
    • Place aside in a safe location.
    Pergunte ao FixBot
    Comentar
  4. Hamilton G5 Ventilation Unit Motherboard Replacement, Main Cover: passo 5, imagem 1 %32
    • Lift the Main Cover (A) from the Ventilation Unit using the Standoff Brackets (B) attached to the Main Cover.
    Pergunte ao FixBot
    Comentar
    Pergunte ao FixBot
    Comentar
  5. Hamilton G5 Ventilation Unit Motherboard Replacement, Ventilation Unit Motherboard: passo 7, imagem 1 %32
    • First, we need to remove the ESM module. It is connected to 2 connector sockets. Disconnect and remove.
    Pergunte ao FixBot
    Comentar
    • Take out the Ventilation Real-time Controller (VRC) SW chip
    Pergunte ao FixBot
    Comentar
  6. Hamilton G5 Ventilation Unit Motherboard Replacement: passo 9, imagem 1 %32
    • Install the ESM Module, by connecting the connectors (A), and the VRC SW chip on the new board.
    Pergunte ao FixBot
    Comentar
  7. Hamilton G5 Ventilation Unit Motherboard Replacement: passo 10, imagem 1 %32
    • Disconnect all cables and connections from the board to the unit.
    Pergunte ao FixBot
    Comentar
  8. Hamilton G5 Ventilation Unit Motherboard Replacement: passo 11, imagem 1 %32
    • Remove the three Hex screws (B).
    Pergunte ao FixBot
    Comentar
  9. Hamilton G5 Ventilation Unit Motherboard Replacement: passo 12, imagem 1 %32
    • Move the motherboard out then up away from the ventilation unit (C).
    Pergunte ao FixBot
    Comentar
Conclusão
Dane Dormedy
Membro desde: 04/08/20
349 Reputação
Autoria de 3 guias
Equipe
Cal Poly, Team S7-G25, Paton Spring 2020 Membro de Cal Poly, Team S7-G25, Paton Spring 2020
CPSU-PATON-S20S7G25
6 Membros
Autoria de 11 guias
0Comentários do guia
Comentar
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 3
Últimos 30 dias: 34
Ao todo: 515
