Ir para o conteúdo principal
Hamilton G5 Internal and Extended Battery Replacement
Equipamento Médico
Nem o iFixit nem este guia de reparo são endossados ou afiliados ao fabricante do dispositivo médico.
O que você precisa
  1. Hamilton G5 Internal and Extended Battery Replacement, Rail: passo 1, imagem 1 %32
    • Remove 4 Hex Allen screws (A) from the Rail surrounding the Ventilation Unit.
    Pergunte ao FixBot
    Comentar
  2. Hamilton G5 Internal and Extended Battery Replacement: passo 2, imagem 1 %32
    • Remove the Rail (B).
    Pergunte ao FixBot
    Comentar
  3. Hamilton G5 Internal and Extended Battery Replacement: passo 3, imagem 1 %32
    • The Standoff Brackets (C) remain with the Main Cover.
    Pergunte ao FixBot
    Comentar
    • Place aside in a safe location.
    Pergunte ao FixBot
    Comentar
  4. Hamilton G5 Internal and Extended Battery Replacement, Main Cover: passo 5, imagem 1 %32
    • Lift the Main Cover (A) from the Ventilation Unit using the Standoff Brackets (B) attached to the Main Cover.
    Pergunte ao FixBot
    Comentar
    Pergunte ao FixBot
    Comentar
  5. Hamilton G5 Internal and Extended Battery Replacement, Internal and Extended Battery: passo 7, imagem 1 %32
    • Unscrew the 4 Hex Allen M4x8 screws (A), 2 on each side of the cover.
    • Lower the Front Cover (B) to remove it.
    • Disconnect the Alarm Status Display Connector (D) and set aside.
    Pergunte ao FixBot
    Comentar
  6. Hamilton G5 Internal and Extended Battery Replacement: passo 8, imagem 1 %32
    • Remove the 8 Hex Allen screws M4x8 (A) located on the side of the ventilator.
    • Locate internal battery (B) and slide it out.
    • Disconnect battery cable (C) and fully remove battery assembly.
    Pergunte ao FixBot
    Comentar
  7. Hamilton G5 Internal and Extended Battery Replacement: passo 9, imagem 1 %32
    • Remove 2 Hex Nuts, Washers, (D) and Cross Bar (E) from assembly.
    • Slide internal battery out from battery assembly.
    Pergunte ao FixBot
    Comentar
  8. Hamilton G5 Internal and Extended Battery Replacement: passo 10, imagem 1 %32
    • Extended Battery
    • Depress battery latch on right side (follow yellow arrow in image).
    • Slide the battery out of bracket to remove.
    Pergunte ao FixBot
    Comentar
Conclusão
Heidi Silk
Membro desde: 04/07/20
139 Reputação
Autoria de 1 guia
Equipe
Cal Poly, Team S7-G25, Paton Spring 2020 Membro de Cal Poly, Team S7-G25, Paton Spring 2020
CPSU-PATON-S20S7G25
6 Membros
Autoria de 11 guias
0Comentários do guia
Comentar
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 6
Últimos 30 dias: 43
Ao todo: 1,352
