Ir para o conteúdo principal
Hamilton Beach 70740 Motor Replacement
Guia arquivado
Este guia é mantido exclusivamente para fins históricos. Use a versão atualizada do guia para executar o reparo.
O que você precisa
  1. Hamilton Beach 70740 Motor Replacement, Base Removal: passo 1, imagem 1 %32 Hamilton Beach 70740 Motor Replacement, Base Removal: passo 1, imagem 2 %32 Hamilton Beach 70740 Motor Replacement, Base Removal: passo 1, imagem 3 %32
    • Hold the food processor upside down and remove the two screws indicated with a screwdriver. Once unscrewed, remove the two rubber suction pads.
    Pergunte ao FixBot
    Comentar
  2. Hamilton Beach 70740 Motor Replacement: passo 2, imagem 1 %32 Hamilton Beach 70740 Motor Replacement: passo 2, imagem 2 %32
    • Use a spudger to remove the 4 rubber base pads located at the corners of the device.
    Pergunte ao FixBot
    Comentar
  3. Hamilton Beach 70740 Motor Replacement: passo 3, imagem 1 %32
    • Unscrew all 4 screws that are located beneath the pads with a screwdriver and remove the plastic grey base.
    Pergunte ao FixBot
    Comentar
  4. Hamilton Beach 70740 Motor Replacement: passo 4, imagem 1 %32
    • Remove the screws indicated with a screw driver.
    Pergunte ao FixBot
    Comentar
  5. Hamilton Beach 70740 Motor Replacement: passo 5, imagem 1 %32
    • Remove the two screws behind the knob with a screwdriver.
    Pergunte ao FixBot
    Comentar
  6. Hamilton Beach 70740 Motor Replacement, Motor/Cord: passo 6, imagem 1 %32
    • Use a regular nylon spudger to remove the plastic caps at these locations with moderate pressure.
    • When working with electronics, it's important to choose a tool that's ESD-safe to avoid accidental damage to the device. The regular black nylon spudger or a plastic opening tool should be used whenever possible.
    • Apply pressure at the edge of the plastic cap circles. Apply stress elsewhere may damage the device.
    • Note that the plastic caps are glued
    Pergunte ao FixBot
    Comentar
  7. Hamilton Beach 70740 Motor Replacement: passo 7, imagem 1 %32
    • Remove the 4 screws located under the plastic caps with a screw driver.
    Pergunte ao FixBot
    Comentar
  8. Hamilton Beach 70740 Motor Replacement: passo 8, imagem 1 %32 Hamilton Beach 70740 Motor Replacement: passo 8, imagem 2 %32
    • Lift and remove the plastic gears at the center of the device.
    • Remove any grease residue underneath the plastic gears.
    Pergunte ao FixBot
    Comentar
  9. Hamilton Beach 70740 Motor Replacement: passo 9, imagem 1 %32 Hamilton Beach 70740 Motor Replacement: passo 9, imagem 2 %32
    • Remove the remaining screws to unhinge the motor located at the center of the device using a screw driver.
    Pergunte ao FixBot
    Comentar
  10. Hamilton Beach 70740 Motor Replacement, Motor: passo 10, imagem 1 %32
    • Remove to electrical cap to the positive terminal(black terminal), and undo the wiring.
    Pergunte ao FixBot
    Comentar
  11. Hamilton Beach 70740 Motor Replacement: passo 11, imagem 1 %32
    • Remove the electrical cap to the negative end(red wire), and undo the wiring. Once this is complete reconstruct the wiring with the new motor.
    Pergunte ao FixBot
    Comentar
Conclusão
David Gedeon
Membro desde: 09/17/15
806 Reputação
Autoria de 6 guias
Equipe
IUPUI, Team 1-1, Baechle Fall 2015 Membro de IUPUI, Team 1-1, Baechle Fall 2015
IUPUI-BAECHLE-F15S1G1
4 Membros
Autoria de 14 guias
0Comentários do guia
Comentar
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 7
Últimos 30 dias: 19
Ao todo: 822
