Ir para o conteúdo principal
Hamilton Beach 70740 Internal switch Replacement
O que você precisa
    1. Hamilton Beach 70740 Internal switch Replacement, Bowl and Lid: passo 1, imagem 1 %32 Hamilton Beach 70740 Internal switch Replacement, Bowl and Lid: passo 1, imagem 2 %32
      • Turn the bowl counterclockwise and lift.
      Pergunte ao FixBot
      Comentar
    1. Hamilton Beach 70740 Internal switch Replacement, Power Knob: passo 2, imagem 1 %32 Hamilton Beach 70740 Internal switch Replacement, Power Knob: passo 2, imagem 2 %32 Hamilton Beach 70740 Internal switch Replacement, Power Knob: passo 2, imagem 3 %32
      Ferramenta utilizada neste passo:
      Heavy-Duty Spudger
      Pergunte ao FixBot
      Comentar
    1. Hamilton Beach 70740 Internal switch Replacement, Base: passo 3, imagem 1 %32 Hamilton Beach 70740 Internal switch Replacement, Base: passo 3, imagem 2 %32
      • Using a #2 Phillips head screwdriver, remove the two 11 mm screws from the base.
      • Pull suction cups straight out.
      Pergunte ao FixBot
      Comentar
    2. Hamilton Beach 70740 Internal switch Replacement: passo 4, imagem 1 %32 Hamilton Beach 70740 Internal switch Replacement: passo 4, imagem 2 %32 Hamilton Beach 70740 Internal switch Replacement: passo 4, imagem 3 %32
      Heavy-Duty Spudger
      • Remove rubber caps using the heavy duty spudger.
      • Remove the four 11 mm screws using the #2 Phillips head screwdriver.
      • Pull base straight out.
      Pergunte ao FixBot
      Comentar
    1. Hamilton Beach 70740 Internal switch Replacement, Internal switch: passo 5, imagem 1 %32 Hamilton Beach 70740 Internal switch Replacement, Internal switch: passo 5, imagem 2 %32
      • Remove the two 11 mm screws using the #2 Phillips head screwdriver.
      Pergunte ao FixBot
      Comentar
    2. Hamilton Beach 70740 Internal switch Replacement: passo 6, imagem 1 %32 Hamilton Beach 70740 Internal switch Replacement: passo 6, imagem 2 %32
      • Cut all four red wires using the wire stripper crimping tool.
      • Using the wire stripper crimping tool strip the ends of each red wire and insert them into a new wiring connector cap, then crimp firmly.
      • Cut the white wire using the stripper crimping tool.
      • Using the wire stripper crimping tool strip the ends of each of the white wires and insert them into the opposite ends of a parallel connector, then crimp firmly.
      Pergunte ao FixBot
      Comentar
Conclusão
Equipe
USF Tampa, Team 17-4, Blackwell Spring 2017 Membro de USF Tampa, Team 17-4, Blackwell Spring 2017
USFT-BLACKWELL-S17S17G4
3 Membros
Autoria de 21 guias
2Comentários do guia
On our unit the control knob became stuck. Where can I get a new control knob? Do you happen to know the part number?
Mitchell Arends - Responder Compartilhar
I used a hair dryer and that did the trick, but am wondering if WD 40 would work as well. I went online e with the company and they want $2.00 for tech advice which is dumb to me. At first I thought it was the locking device on top; it is actually the pulse switch and my machine is just over a year old.
joanneferrato - Responder Compartilhar
Comentar
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 2
Últimos 30 dias: 24
Ao todo: 1,326
