Ir para o conteúdo principal
Hamilton Beach 64650 Mixer Release Button Replacement
O que você precisa
    1. Hamilton Beach 64650 Mixer Release Button Replacement, Mixer Release Button: passo 1, imagem 1 %32 Hamilton Beach 64650 Mixer Release Button Replacement, Mixer Release Button: passo 1, imagem 2 %32 Hamilton Beach 64650 Mixer Release Button Replacement, Mixer Release Button: passo 1, imagem 3 %32
      • Depress mixer release button fully and lift mixer off of the platform.
      • Remove the bowl from the stand.
      Pergunte ao FixBot
      Comentar
    2. Hamilton Beach 64650 Mixer Release Button Replacement: passo 2, imagem 1 %32 Hamilton Beach 64650 Mixer Release Button Replacement: passo 2, imagem 2 %32 Hamilton Beach 64650 Mixer Release Button Replacement: passo 2, imagem 3 %32
      • Remove and set aside the three 1.3 mm Philips #2 screws holding the plastic cover in place.
      Pergunte ao FixBot
      Comentar
    3. Hamilton Beach 64650 Mixer Release Button Replacement: passo 3, imagem 1 %32 Hamilton Beach 64650 Mixer Release Button Replacement: passo 3, imagem 2 %32
      • Shift the cover to allow the plastic retaining hook to fit through the hole easily.
      • Lift the cover away.
      Pergunte ao FixBot
      Comentar
    4. Hamilton Beach 64650 Mixer Release Button Replacement: passo 4, imagem 1 %32 Hamilton Beach 64650 Mixer Release Button Replacement: passo 4, imagem 2 %32 Hamilton Beach 64650 Mixer Release Button Replacement: passo 4, imagem 3 %32
      • Fully depress the mixer release button, pushing it through the mounting hole.
      • Push the button slightly upwards once it is inside the stand to access the spring underneath it.
      • Carefully remove the button from the stand while leaving spring in place.
      Pergunte ao FixBot
      Comentar
    5. Hamilton Beach 64650 Mixer Release Button Replacement: passo 5, imagem 1 %32 Hamilton Beach 64650 Mixer Release Button Replacement: passo 5, imagem 2 %32 Hamilton Beach 64650 Mixer Release Button Replacement: passo 5, imagem 3 %32
      • Depress the spring slightly and lift upward to remove.
      • Replace with a new spring to have a working button again.
      Pergunte ao FixBot
      Comentar
Conclusão
Gwen Davis
Membro desde: 03/24/16
519 Reputação
Autoria de 5 guias
Equipe
0Comentários do guia
Comentar
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 7
Últimos 30 dias: 28
Ao todo: 1,870
