Ir para o conteúdo principal
Hamilton Beach 51101BA Power Button Replacement
O que você precisa
    1. Hamilton Beach 51101BA Power Button Replacement, Power Button: passo 1, imagem 1 %32 Hamilton Beach 51101BA Power Button Replacement, Power Button: passo 1, imagem 2 %32 Hamilton Beach 51101BA Power Button Replacement, Power Button: passo 1, imagem 3 %32
      • Remove the container from the base.
      • Hold the blender and the container, then twist the container in a clockwise motion.
      • Make sure to follow the lock and unlock markings on the container.
      Pergunte ao FixBot
      Comentar
    2. Hamilton Beach 51101BA Power Button Replacement: passo 2, imagem 1 %32
      • Turn the blender so the bottom is facing you.
      • Using a Phillips #2 screwdriver, remove the two 5 mm Phillips screws from the base.
      Pergunte ao FixBot
      Comentar
    3. Hamilton Beach 51101BA Power Button Replacement: passo 3, imagem 1 %32
      • Using a Phillips #2 screwdriver, remove the two 5 mm Phillips screws from the motor platform.
      Pergunte ao FixBot
      Comentar
    4. Hamilton Beach 51101BA Power Button Replacement: passo 4, imagem 1 %32 Hamilton Beach 51101BA Power Button Replacement: passo 4, imagem 2 %32
      • Unhinge the motor platform from the blender.
      • You may need a plastic spudger to unhinge the plastic bottom piece from the base of the blender.
      • You do not need to completely remove this piece from the base.
      Pergunte ao FixBot
      Comentar
    5. Hamilton Beach 51101BA Power Button Replacement: passo 5, imagem 1 %32
      • Pull out the rectangular green piece.
      • This is the actual power button.
      Pergunte ao FixBot
      Comentar
    6. Hamilton Beach 51101BA Power Button Replacement: passo 6, imagem 1 %32
      • Some experience in soldering is required!
      • On the back of the power button, desolder the red and grey wires that are connected to the piece.
      Pergunte ao FixBot
      Comentar
Conclusão
Equipe
USF Tampa, Team 2-5, Sullivan Fall 2015 Membro de USF Tampa, Team 2-5, Sullivan Fall 2015
USFT-SULLIVAN-F15S2G5
4 Membros
Autoria de 11 guias
0Comentários do guia
Comentar
Visualizações:
Últimas 24 horas: 2
Últimos 7 dias: 8
Últimos 30 dias: 24
Ao todo: 4,035
