Ir para o conteúdo principal
Hamilton Beach 51101BA Motor Replacement
O que você precisa
  1. Hamilton Beach 51101BA Motor Replacement, Rotor: passo 1, imagem 1 %32 Hamilton Beach 51101BA Motor Replacement, Rotor: passo 1, imagem 2 %32 Hamilton Beach 51101BA Motor Replacement, Rotor: passo 1, imagem 3 %32
    • Remove the container from the blender.
    • Hold the blender and the container, then twist the container in a clockwise motion.
    • Make sure to follow the lock and unlock markings on the container.
    Pergunte ao FixBot
    Comentar
  2. Hamilton Beach 51101BA Motor Replacement: passo 2, imagem 1 %32
    • Turn the blender so the bottom is facing you.
    • Using a Phillips #2 screwdriver, remove the two 5 mm Phillips screws from the base.
    Pergunte ao FixBot
    Comentar
  3. Hamilton Beach 51101BA Motor Replacement: passo 3, imagem 1 %32
    • Using a Phillips #2 screwdriver, remove the two 5 mm Phillips screws from the motor platform.
    Pergunte ao FixBot
    Comentar
  4. Hamilton Beach 51101BA Motor Replacement: passo 4, imagem 1 %32
    • Unhinge the plastic motor platform from the blender.
    • You may need a plastic spudger to unhinge the motor platform from the blender.
    Pergunte ao FixBot
    Comentar
  5. Hamilton Beach 51101BA Motor Replacement: passo 5, imagem 1 %32 Hamilton Beach 51101BA Motor Replacement: passo 5, imagem 2 %32
    • Using a spudger, carefully insert the tip into the coil of wire around motor.
    • This is used to hold the rotating piece of the motor still.
    Pergunte ao FixBot
    Comentar
  6. Hamilton Beach 51101BA Motor Replacement: passo 6, imagem 1 %32
    • Remove the white rotor piece by rotating it counter-clockwise.
    • While rotating, make sure the rotating piece of the motor remains still.
    Pergunte ao FixBot
    Comentar
  7. Hamilton Beach 51101BA Motor Replacement, Motor: passo 7, imagem 1 %32 Hamilton Beach 51101BA Motor Replacement, Motor: passo 7, imagem 2 %32
    • Move the motor platform to the side.
    • Lift up the motor and remove it from the blender.
    Pergunte ao FixBot
    Comentar
  8. Hamilton Beach 51101BA Motor Replacement: passo 8, imagem 1 %32
    • Some soldering experience required!
    • Desolder the red wire from the green plastic piece.
    Pergunte ao FixBot
    Comentar
  9. Hamilton Beach 51101BA Motor Replacement: passo 9, imagem 1 %32
    • Cut the thin black wire from the wire cap.
    Pergunte ao FixBot
    Comentar
Conclusão
Uma outra pessoa concluiu este guia.
Andrew Huff
Membro desde: 09/04/15
616 Reputação
Autoria de 3 guias
Equipe
USF Tampa, Team 2-5, Sullivan Fall 2015 Membro de USF Tampa, Team 2-5, Sullivan Fall 2015
USFT-SULLIVAN-F15S2G5
4 Membros
Autoria de 6 guias
2Comentários do guia
This article appears to be unfinished. You cut 2 wires at the end... then what? Reconnecting them doesn't make any sense.
Geo Jack Jack - Responder Compartilhar
Que tipo de motor tengo que comprar?
hugoalex521 - Responder Compartilhar
Comentar
Visualizações:
Últimas 24 horas: 2
Últimos 7 dias: 16
Últimos 30 dias: 70
Ao todo: 8,827
