Ir para o conteúdo principal
Hamilton Beach 25460Z Handle Replacement
O que você precisa
    1. Hamilton Beach 25460Z Handle Replacement, Handle: passo 1, imagem 1 %32 Hamilton Beach 25460Z Handle Replacement, Handle: passo 1, imagem 2 %32
      • Unplug your device before proceeding with disassembly.
      • On the back of the press, remove the locking washer by prying upwards with the nylon or metal spudger tool.
      • Repeat for the other washer across from the first one.
      Pergunte ao FixBot
      Comentar
    2. Hamilton Beach 25460Z Handle Replacement: passo 2, imagem 1 %32 Hamilton Beach 25460Z Handle Replacement: passo 2, imagem 2 %32
      • Using any long, thin object, push the 43mm bolt from the inside towards the outside to expose the end of the bolt.
      • Pull the end of the bolt out to completely remove it.
      • Repeat for the second bolt.
      Pergunte ao FixBot
      Comentar
    3. Hamilton Beach 25460Z Handle Replacement: passo 3, imagem 1 %32 Hamilton Beach 25460Z Handle Replacement: passo 3, imagem 2 %32
      • Using the 4.0mm Allen Wrench, unscrew the two 26mm bolts connecting the handle to the upper heating element housing on both sides.
      Pergunte ao FixBot
      Comentar
    4. Hamilton Beach 25460Z Handle Replacement: passo 4, imagem 1 %32
      • Unscrew the locking knob all the way to remove it.
      Pergunte ao FixBot
      Comentar
    5. Hamilton Beach 25460Z Handle Replacement: passo 5, imagem 1 %32 Hamilton Beach 25460Z Handle Replacement: passo 5, imagem 2 %32 Hamilton Beach 25460Z Handle Replacement: passo 5, imagem 3 %32
      • Slide the locking knob couple down to the base of the handle, then pull up on the free end of the handle. It will easily pop off.
      Pergunte ao FixBot
      Comentar
Conclusão
Uma outra pessoa concluiu este guia.
Equipe
Cal Poly, Team 6-27, Amido Winter 2015 Membro de Cal Poly, Team 6-27, Amido Winter 2015
CPSU-AMIDO-W15S6G27
4 Membros
Autoria de 25 guias
2Comentários do guia
And where do I buy the handle?? I can’t find it anywhere
if someone see this, please help me!
Tulio
Tulioalejandro@icloud.com
tulio181 - Responder Compartilhar
I too am looking for a replacement handle! They get brittle from the heat...mine just snapped on the left side..
salikah11@yahoo.ca
DEE EFF - Responder Compartilhar
Comentar
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 11
Últimos 30 dias: 39
Ao todo: 2,460
