Ir para o conteúdo principal
HTC Wizard 200 LCD Screen Replacement
O que você precisa
  1. HTC Wizard 200 LCD Screen Replacement, Battery: passo 1, imagem 1 %32 HTC Wizard 200 LCD Screen Replacement, Battery: passo 1, imagem 2 %32
    • To expose the battery, remove the outer case with your fingernail.
    • Remove the battery by pulling the black tab.
    Pergunte ao FixBot
    Comentar
  2. HTC Wizard 200 LCD Screen Replacement, Back Panel: passo 2, imagem 1 %32
    Ferramenta utilizada neste passo:
    Spudger
    $3.99
    • Insert the flat end of the spudger into the two notches on the back of the camera cover and pry them up.
    Pergunte ao FixBot
    Comentar
  3. HTC Wizard 200 LCD Screen Replacement: passo 3, imagem 1 %32 HTC Wizard 200 LCD Screen Replacement: passo 3, imagem 2 %32
    Spudger
    $3.99
    • Work the spudger around the edges of the camera cover until it comes off.
    Pergunte ao FixBot
    Comentar
  4. HTC Wizard 200 LCD Screen Replacement: passo 4, imagem 1 %32 HTC Wizard 200 LCD Screen Replacement: passo 4, imagem 2 %32
    T5 Torx Screwdriver
    $5.49
    • Remove the four 6 mm screws with the T5 Torx screwdriver.
    • One of the screws is under the "void" sticker.
    Pergunte ao FixBot
    Comentar
  5. HTC Wizard 200 LCD Screen Replacement: passo 5, imagem 1 %32 HTC Wizard 200 LCD Screen Replacement: passo 5, imagem 2 %32 HTC Wizard 200 LCD Screen Replacement: passo 5, imagem 3 %32
    • Insert the flat end of an iFixit opening tool between the side and inner covers to create a gap.
    • Work the tool around the edges until all the clips release.
    Pergunte ao FixBot
    Comentar
  6. HTC Wizard 200 LCD Screen Replacement: passo 6, imagem 1 %32 HTC Wizard 200 LCD Screen Replacement: passo 6, imagem 2 %32
    • Once all the clips are open, remove the inner panel from the phone.
    Pergunte ao FixBot
    Comentar
  7. HTC Wizard 200 LCD Screen Replacement, Motherboard: passo 7, imagem 1 %32
    Spudger
    $3.99
    • Use the spudger to pry the camera off.
    Pergunte ao FixBot
    Comentar
  8. HTC Wizard 200 LCD Screen Replacement: passo 8, imagem 1 %32 HTC Wizard 200 LCD Screen Replacement: passo 8, imagem 2 %32
    • Using tweezers, flip the connector latch away from the motherboard.
    • Detach the flexible connection from under the connector latch.
    Pergunte ao FixBot
    Comentar
  9. HTC Wizard 200 LCD Screen Replacement: passo 9, imagem 1 %32
    • Slide the keyboard into the open position.
    Pergunte ao FixBot
    Comentar
  10. HTC Wizard 200 LCD Screen Replacement: passo 10, imagem 1 %32 HTC Wizard 200 LCD Screen Replacement: passo 10, imagem 2 %32
    Spudger
    $3.99
    • Lift the motherboard out of the case using the spudger.
    • Expose the underside of the motherboard using your hands.
    Pergunte ao FixBot
    Comentar
  11. HTC Wizard 200 LCD Screen Replacement: passo 11, imagem 1 %32 HTC Wizard 200 LCD Screen Replacement: passo 11, imagem 2 %32
    • Remove the flexible connection from the motherboard.
    • Caution: Removing the connection too fast may cause damage to the connection and cables.
    Pergunte ao FixBot
    Comentar
  12. HTC Wizard 200 LCD Screen Replacement, Keyboard Slider: passo 12, imagem 1 %32 HTC Wizard 200 LCD Screen Replacement, Keyboard Slider: passo 12, imagem 2 %32 HTC Wizard 200 LCD Screen Replacement, Keyboard Slider: passo 12, imagem 3 %32
    T5 Torx Screwdriver
    $5.49
    • Remove the four 5mm screws with the T5 Torx screwdriver.
    • Remove the keyboard slider from the main body.
    Pergunte ao FixBot
    Comentar
  13. HTC Wizard 200 LCD Screen Replacement, Screen Cover: passo 13, imagem 1 %32 HTC Wizard 200 LCD Screen Replacement, Screen Cover: passo 13, imagem 2 %32
    • Use the T5 Torx screwdriver to remove four 5mm screws that secure the back of the screen casing.
    Pergunte ao FixBot
    Comentar
  14. HTC Wizard 200 LCD Screen Replacement: passo 14, imagem 1 %32 HTC Wizard 200 LCD Screen Replacement: passo 14, imagem 2 %32
    • Insert the plastic opening tool between the front panel and the rear panel and pry open to reach the screen.
    Pergunte ao FixBot
    Comentar
  15. HTC Wizard 200 LCD Screen Replacement: passo 15, imagem 1 %32 HTC Wizard 200 LCD Screen Replacement: passo 15, imagem 2 %32
    • Once the rear panel is loose, lift it off of the front panel.
    • The flexible connection will pop loose.
    Pergunte ao FixBot
    Comentar
  16. HTC Wizard 200 LCD Screen Replacement: passo 16, imagem 1 %32
    • Device rotated 90 degrees CCW.
    • Remove the yellow anti-static tape.
    Pergunte ao FixBot
    Comentar
  17. HTC Wizard 200 LCD Screen Replacement: passo 17, imagem 1 %32 HTC Wizard 200 LCD Screen Replacement: passo 17, imagem 2 %32
    • Unscrew the two 3mm phillips #0 screws from the bottom of the device that secure the rigid flex board to the screen panel.
    Pergunte ao FixBot
    Comentar
  18. HTC Wizard 200 LCD Screen Replacement: passo 18, imagem 1 %32
    • Device rotated 180 degrees CW.
    • Unscrew the two 3mm Phillips #0 screws from the top of the device that secure the rigid flex board to the screen panel.
    Pergunte ao FixBot
    Comentar
  19. HTC Wizard 200 LCD Screen Replacement: passo 19, imagem 1 %32
    • Unhinge the flexible connection and use the tweezers to disconnect.
    Pergunte ao FixBot
    Comentar
  20. HTC Wizard 200 LCD Screen Replacement: passo 20, imagem 1 %32
    • Now that the rigid flex board is loose, remove it from the screen.
    Pergunte ao FixBot
    Comentar
  21. HTC Wizard 200 LCD Screen Replacement, LCD Screen: passo 21, imagem 1 %32 HTC Wizard 200 LCD Screen Replacement, LCD Screen: passo 21, imagem 2 %32
    • Simply pull out the loose screen.
    Pergunte ao FixBot
    Comentar
Conclusão
Uma outra pessoa concluiu este guia.
Kyle Champ
Membro desde: 10/03/11
225 Reputação
Autoria de 12 guias
Equipe
Cal Poly, Team 20-27, Maness Fall 2011 Membro de Cal Poly, Team 20-27, Maness Fall 2011
CPSU-MANESS-F11S20G27
4 Membros
Autoria de 24 guias
0Comentários do guia
Comentar
Visualizações:
Últimas 24 horas: 3
Últimos 7 dias: 11
Últimos 30 dias: 33
Ao todo: 1,335
