Ir para o conteúdo principal
HTC Wizard 200 Keypad Replacement
O que você precisa
  1. HTC Wizard 200 Keypad Replacement, Battery: passo 1, imagem 1 %32 HTC Wizard 200 Keypad Replacement, Battery: passo 1, imagem 2 %32
    • To expose the battery, remove the outer case with your fingernail.
    • Remove the battery by pulling the black tab.
    Pergunte ao FixBot
    Comentar
  2. HTC Wizard 200 Keypad Replacement, Back Panel: passo 2, imagem 1 %32
    Ferramenta utilizada neste passo:
    Spudger
    $3.99
    • Insert the flat end of the spudger into the two notches on the back of the camera cover and pry them up.
    Pergunte ao FixBot
    Comentar
  3. HTC Wizard 200 Keypad Replacement: passo 3, imagem 1 %32 HTC Wizard 200 Keypad Replacement: passo 3, imagem 2 %32
    Spudger
    $3.99
    • Work the spudger around the edges of the camera cover until it comes off.
    Pergunte ao FixBot
    Comentar
  4. HTC Wizard 200 Keypad Replacement: passo 4, imagem 1 %32 HTC Wizard 200 Keypad Replacement: passo 4, imagem 2 %32
    T5 Torx Screwdriver
    $5.49
    • Remove the four 6 mm screws with the T5 Torx screwdriver.
    • One of the screws is under the "void" sticker.
    Pergunte ao FixBot
    Comentar
  5. HTC Wizard 200 Keypad Replacement: passo 5, imagem 1 %32 HTC Wizard 200 Keypad Replacement: passo 5, imagem 2 %32 HTC Wizard 200 Keypad Replacement: passo 5, imagem 3 %32
    • Insert the flat end of an iFixit opening tool between the side and inner covers to create a gap.
    • Work the tool around the edges until all the clips release.
    Pergunte ao FixBot
    Comentar
  6. HTC Wizard 200 Keypad Replacement: passo 6, imagem 1 %32 HTC Wizard 200 Keypad Replacement: passo 6, imagem 2 %32
    • Once all the clips are open, remove the inner panel from the phone.
    Pergunte ao FixBot
    Comentar
  7. HTC Wizard 200 Keypad Replacement, Motherboard: passo 7, imagem 1 %32
    Spudger
    $3.99
    • Use the spudger to pry the camera off.
    Pergunte ao FixBot
    Comentar
  8. HTC Wizard 200 Keypad Replacement: passo 8, imagem 1 %32 HTC Wizard 200 Keypad Replacement: passo 8, imagem 2 %32
    • Using tweezers, flip the connector latch away from the motherboard.
    • Detach the flexible connection from under the connector latch.
    Pergunte ao FixBot
    Comentar
  9. HTC Wizard 200 Keypad Replacement: passo 9, imagem 1 %32
    • Slide the keyboard into the open position.
    Pergunte ao FixBot
    Comentar
  10. HTC Wizard 200 Keypad Replacement: passo 10, imagem 1 %32 HTC Wizard 200 Keypad Replacement: passo 10, imagem 2 %32
    Spudger
    $3.99
    • Lift the motherboard out of the case using the spudger.
    • Expose the underside of the motherboard using your hands.
    Pergunte ao FixBot
    Comentar
  11. HTC Wizard 200 Keypad Replacement: passo 11, imagem 1 %32 HTC Wizard 200 Keypad Replacement: passo 11, imagem 2 %32
    • Remove the flexible connection from the motherboard.
    • Caution: Removing the connection too fast may cause damage to the connection and cables.
    Pergunte ao FixBot
    Comentar
  12. HTC Wizard 200 Keypad Replacement, Keyboard Slider: passo 12, imagem 1 %32 HTC Wizard 200 Keypad Replacement, Keyboard Slider: passo 12, imagem 2 %32 HTC Wizard 200 Keypad Replacement, Keyboard Slider: passo 12, imagem 3 %32
    T5 Torx Screwdriver
    $5.49
    • Remove the four 5mm screws with the T5 Torx screwdriver.
    • Remove the keyboard slider from the main body.
    Pergunte ao FixBot
    Comentar
  13. HTC Wizard 200 Keypad Replacement, Keypad: passo 13, imagem 1 %32 HTC Wizard 200 Keypad Replacement, Keypad: passo 13, imagem 2 %32
    • Use a screwdriver to remove eight 2mm Phillips screws that secure the keypad to the keyboard slider.
    Pergunte ao FixBot
    Comentar
  14. HTC Wizard 200 Keypad Replacement: passo 14, imagem 1 %32 HTC Wizard 200 Keypad Replacement: passo 14, imagem 2 %32
    • Use the plastic opening tool to gently lift up the keypad.
    Pergunte ao FixBot
    Comentar
Conclusão
Kyle Champ
Membro desde: 10/03/11
225 Reputação
Autoria de 12 guias
Equipe
Cal Poly, Team 20-27, Maness Fall 2011 Membro de Cal Poly, Team 20-27, Maness Fall 2011
CPSU-MANESS-F11S20G27
4 Membros
Autoria de 24 guias
0Comentários do guia
Comentar
Visualizações:
Últimas 24 horas: 1
Últimos 7 dias: 4
Últimos 30 dias: 23
Ao todo: 982
