Ir para o conteúdo principal
HTC Vive XR Elite Motion Sensor Replacement
O que você precisa
  1. HTC Vive XR Elite Motion Sensor Replacement, Prepare your Vive XR Elite for disassembly: passo 1, imagem 1 %32
    • Before starting this repair, discharge the batteries in your headset below 25%. A charged battery may leak dangerous chemicals or catch fire if damaged.
    • Playing Half Life: Alyx will do the trick!
    • The Vive XR Elite has a proximity sensor that puts the headset in standby mode to save battery when it isn't in use. To drain the battery faster you'll need to use the headset.
  2. HTC Vive XR Elite Motion Sensor Replacement, Disconnect the USB-C power cable: passo 2, imagem 1 %32 HTC Vive XR Elite Motion Sensor Replacement, Disconnect the USB-C power cable: passo 2, imagem 2 %32
    • Disconnect the USB-C power cable.
  3. HTC Vive XR Elite Motion Sensor Replacement, Disconnect the battery cradle: passo 3, imagem 1 %32 HTC Vive XR Elite Motion Sensor Replacement, Disconnect the battery cradle: passo 3, imagem 2 %32 HTC Vive XR Elite Motion Sensor Replacement, Disconnect the battery cradle: passo 3, imagem 3 %32
    • Press the release button on the right battery cradle temple slot.
    • Pull the battery cradle away from the right temple slot to disconnect it.
  4. HTC Vive XR Elite Motion Sensor Replacement: passo 4, imagem 1 %32 HTC Vive XR Elite Motion Sensor Replacement: passo 4, imagem 2 %32 HTC Vive XR Elite Motion Sensor Replacement: passo 4, imagem 3 %32
    • Repeat the previous step for the left temple slot.
  5. HTC Vive XR Elite Motion Sensor Replacement, Separate the headset and battery cradle: passo 5, imagem 1 %32
    • Separate the headset and battery cradle.
  6. HTC Vive XR Elite Motion Sensor Replacement, Remove the face cushion: passo 6, imagem 1 %32 HTC Vive XR Elite Motion Sensor Replacement, Remove the face cushion: passo 6, imagem 2 %32 HTC Vive XR Elite Motion Sensor Replacement, Remove the face cushion: passo 6, imagem 3 %32
    • The face cushion is attached to the headset with two magnets. You'll feel the pull of the magnets as you remove it.
    • Grip the middle of the face cushion with your fingers and pull back to remove it.
  7. HTC Vive XR Elite Motion Sensor Replacement, Remove the screw covers: passo 7, imagem 1 %32 HTC Vive XR Elite Motion Sensor Replacement, Remove the screw covers: passo 7, imagem 2 %32
    Ferramenta utilizada neste passo:
    • Use tweezers to remove the six screw covers from the right temple.
  8. HTC Vive XR Elite Motion Sensor Replacement, Unfasten the right temple: passo 8, imagem 1 %32 HTC Vive XR Elite Motion Sensor Replacement, Unfasten the right temple: passo 8, imagem 2 %32
    • Use a T5 Torx screwdriver to remove the six 4.9 mm‑long screws securing the two right temple halves.
    • Use a T5 Torx screwdriver to remove the two 3.5 mm‑long screws securing the right hinge cover.
  9. HTC Vive XR Elite Motion Sensor Replacement, Remove the outer hinge cover: passo 9, imagem 1 %32 HTC Vive XR Elite Motion Sensor Replacement, Remove the outer hinge cover: passo 9, imagem 2 %32 HTC Vive XR Elite Motion Sensor Replacement, Remove the outer hinge cover: passo 9, imagem 3 %32
    • Insert the flat end of a spudger in the gap between the right outer and inner hinge covers.
    • Slide the spudger along the gap to separate the clips securing the outer hinge cover.
    • Remove the outer hinge cover.
  10. HTC Vive XR Elite Motion Sensor Replacement, Remove the outer temple: passo 10, imagem 1 %32 HTC Vive XR Elite Motion Sensor Replacement, Remove the outer temple: passo 10, imagem 2 %32 HTC Vive XR Elite Motion Sensor Replacement, Remove the outer temple: passo 10, imagem 3 %32
    • Insert the flat end of a spudger in the gap between the outer and inner temple.
    • Slide the spudger along the gap to separate the clips securing the outer temple.
  11. HTC Vive XR Elite Motion Sensor Replacement: passo 11, imagem 1 %32 HTC Vive XR Elite Motion Sensor Replacement: passo 11, imagem 2 %32 HTC Vive XR Elite Motion Sensor Replacement: passo 11, imagem 3 %32
    • Slide the top of the outer temple out of its slot in the hinge.
  12. HTC Vive XR Elite Motion Sensor Replacement: passo 12, imagem 1 %32 HTC Vive XR Elite Motion Sensor Replacement: passo 12, imagem 2 %32
    Tesa 61395 Tape
    $6.99
    • The speaker is lightly adhered to the outer temple.
    • Rotate the outer temple towards you to access the speaker.
    • Slide the flat end of a spudger under the speaker to separate its adhesive.
    • During reassembly, if your speaker adhesive isn't sticky, use double-sided tape to re-adhere the speaker to the outer temple.
  13. HTC Vive XR Elite Motion Sensor Replacement: passo 13, imagem 1 %32 HTC Vive XR Elite Motion Sensor Replacement: passo 13, imagem 2 %32 HTC Vive XR Elite Motion Sensor Replacement: passo 13, imagem 3 %32
    • Thread the outer temple off of the USB‑C cable and remove it.
  14. HTC Vive XR Elite Motion Sensor Replacement: passo 14, imagem 1 %32 HTC Vive XR Elite Motion Sensor Replacement: passo 14, imagem 2 %32
    • Pull the inner temple out of its slot in the hinge and remove it.
  15. HTC Vive XR Elite Motion Sensor Replacement, Peel the hinge tape: passo 15, imagem 1 %32 HTC Vive XR Elite Motion Sensor Replacement, Peel the hinge tape: passo 15, imagem 2 %32
    • Use tweezers to peel back the black tape covering one of the inner hinge cover screws.
  16. HTC Vive XR Elite Motion Sensor Replacement, Unfasten the inner hinge cover: passo 16, imagem 1 %32
    • Use a T5 Torx screwdriver to remove the two screws securing the inner hinge cover:
    • One 3.1 mm‑long screw
    • One 4.9 mm‑long screw
  17. HTC Vive XR Elite Motion Sensor Replacement, Remove the inner hinge cover: passo 17, imagem 1 %32 HTC Vive XR Elite Motion Sensor Replacement, Remove the inner hinge cover: passo 17, imagem 2 %32 HTC Vive XR Elite Motion Sensor Replacement, Remove the inner hinge cover: passo 17, imagem 3 %32
    • Rotate the inner hinge cover off its groove in the frame.
    • Thread the inner hinge cover off of the USB-C and speaker cables and remove it.
  18. HTC Vive XR Elite Motion Sensor Replacement, Remove the screw covers: passo 18, imagem 1 %32 HTC Vive XR Elite Motion Sensor Replacement, Remove the screw covers: passo 18, imagem 2 %32
    • Use tweezers to remove the six screw covers from the left temple.
  19. HTC Vive XR Elite Motion Sensor Replacement, Unfasten the left temple: passo 19, imagem 1 %32 HTC Vive XR Elite Motion Sensor Replacement, Unfasten the left temple: passo 19, imagem 2 %32
    • Use a T5 Torx screwdriver to remove the six 4.9 mm‑long screws securing the two left temple halves.
    • Use a T5 Torx screwdriver to remove the two 3.5 mm‑long screws securing the left hinge cover.
  20. HTC Vive XR Elite Motion Sensor Replacement, Remove the outer hinge cover: passo 20, imagem 1 %32 HTC Vive XR Elite Motion Sensor Replacement, Remove the outer hinge cover: passo 20, imagem 2 %32 HTC Vive XR Elite Motion Sensor Replacement, Remove the outer hinge cover: passo 20, imagem 3 %32
    • Insert the flat end of a spudger in the gap between the left outer and inner hinge covers.
  21. HTC Vive XR Elite Motion Sensor Replacement, Remove the left temple: passo 21, imagem 1 %32 HTC Vive XR Elite Motion Sensor Replacement, Remove the left temple: passo 21, imagem 2 %32
    • Pull the left temple out of its slot in the hinge.
    • Don't try to fully remove it yet, as it's still connected by a cable.
  22. HTC Vive XR Elite Motion Sensor Replacement: passo 22, imagem 1 %32 HTC Vive XR Elite Motion Sensor Replacement: passo 22, imagem 2 %32
    • Slide the spudger along the gap to separate the plastic clips securing the outer temple.
  23. HTC Vive XR Elite Motion Sensor Replacement: passo 23, imagem 1 %32 HTC Vive XR Elite Motion Sensor Replacement: passo 23, imagem 2 %32
    • Pull the outer temple off of its inner half to completely release its plastic clips.
  24. HTC Vive XR Elite Motion Sensor Replacement: passo 24, imagem 1 %32 HTC Vive XR Elite Motion Sensor Replacement: passo 24, imagem 2 %32
    Tesa 61395 Tape
    $6.99
    • Let the speaker rest next to the headset before continuing.
    • During reassembly, if your speaker adhesive isn't sticky, use Tesa 61395 Tape to re-adhere the speaker to the outer temple.
  25. HTC Vive XR Elite Motion Sensor Replacement, Peel the hinge tape: passo 25, imagem 1 %32 HTC Vive XR Elite Motion Sensor Replacement, Peel the hinge tape: passo 25, imagem 2 %32
  26. HTC Vive XR Elite Motion Sensor Replacement, Unfasten the inner hinge cover: passo 26, imagem 1 %32
    • One 3.5 mm‑long screw
  27. HTC Vive XR Elite Motion Sensor Replacement, Reposition the inner hinge cover: passo 27, imagem 1 %32 HTC Vive XR Elite Motion Sensor Replacement, Reposition the inner hinge cover: passo 27, imagem 2 %32 HTC Vive XR Elite Motion Sensor Replacement, Reposition the inner hinge cover: passo 27, imagem 3 %32
    • Don't fully remove the inner hinge cover, as it's connected by the volume button cable.
    • Let the cover hang off its volume button cable for now.
  28. HTC Vive XR Elite Motion Sensor Replacement, Unfasten the face plate: passo 28, imagem 1 %32 HTC Vive XR Elite Motion Sensor Replacement, Unfasten the face plate: passo 28, imagem 2 %32
    • Use a T5 Torx screwdriver to remove the 12 screws securing the face plate:
    • Six 3.5 mm‑long screws
    • Four 4.9 mm‑long screws
    • Two 6.5 mm‑long screws
    • There are two magnets at the top corners of the face plate. As you remove nearby screws, they might stick to them.
  29. HTC Vive XR Elite Motion Sensor Replacement, Unclip the face cover: passo 29, imagem 1 %32 HTC Vive XR Elite Motion Sensor Replacement, Unclip the face cover: passo 29, imagem 2 %32
    • Insert the flat end of the spudger in the gap between the frame and the bottom right corner of the face cover.
    • Pry up with the spudger to release the clips securing the face cover.
  30. HTC Vive XR Elite Motion Sensor Replacement: passo 30, imagem 1 %32 HTC Vive XR Elite Motion Sensor Replacement: passo 30, imagem 2 %32
    • Repeat the prying process for the middle and bottom left portions of the face cover.
  31. HTC Vive XR Elite Motion Sensor Replacement, Reposition the face cover: passo 31, imagem 1 %32 HTC Vive XR Elite Motion Sensor Replacement, Reposition the face cover: passo 31, imagem 2 %32 HTC Vive XR Elite Motion Sensor Replacement, Reposition the face cover: passo 31, imagem 3 %32
    • Don't fully remove the face cover completely, as it's connected by the proximity sensor cable.
    • Lift the face cover and rotate it over the top of the frame.
    • Lay the face cover face up before continuing.
  32. HTC Vive XR Elite Motion Sensor Replacement, Unfasten the proximity sensor: passo 32, imagem 1 %32
    • Use a T5 Torx screwdriver to remove the two 3.3 mm‑long screws securing the proximity sensor cable.
  33. HTC Vive XR Elite Motion Sensor Replacement, Remove the face cover: passo 33, imagem 1 %32 HTC Vive XR Elite Motion Sensor Replacement, Remove the face cover: passo 33, imagem 2 %32
    • Remove the face cover.
  34. HTC Vive XR Elite Motion Sensor Replacement, Reposition the lens assembly: passo 34, imagem 1 %32 HTC Vive XR Elite Motion Sensor Replacement, Reposition the lens assembly: passo 34, imagem 2 %32
    • Pull the two lenses outward so they're as far apart as possible.
  35. HTC Vive XR Elite Motion Sensor Replacement, Unfasten the lens assembly: passo 35, imagem 1 %32
    • Use a T5 Torx screwdriver to remove the four screws securing the lens assembly:
    • Three 4.9 mm‑long screws
    • One 3.3 mm‑long screw
  36. HTC Vive XR Elite Motion Sensor Replacement, Remove the brackets: passo 36, imagem 1 %32 HTC Vive XR Elite Motion Sensor Replacement, Remove the brackets: passo 36, imagem 2 %32 HTC Vive XR Elite Motion Sensor Replacement, Remove the brackets: passo 36, imagem 3 %32
    • The screw brackets are secured with clips and adhesive.
    • Use tweezers to pull the left screw bracket of its post in the frame.
    • This may require some force. Be careful not to scratch any surrounding components.
    • Repeat this process for the right bracket.
    • During reassembly, use tweezers to align the brackets on their posts. Press down with the flat end of a spudger to engage and re-adhere the clips.
  37. HTC Vive XR Elite Motion Sensor Replacement, Reposition the lens assembly: passo 37, imagem 1 %32 HTC Vive XR Elite Motion Sensor Replacement, Reposition the lens assembly: passo 37, imagem 2 %32
    • Lift the bottom of the lens assembly up to separate the bottom rails from their slots in the frame.
  38. HTC Vive XR Elite Motion Sensor Replacement: passo 38, imagem 1 %32 HTC Vive XR Elite Motion Sensor Replacement: passo 38, imagem 2 %32 HTC Vive XR Elite Motion Sensor Replacement: passo 38, imagem 3 %32
    • Pull the lens assembly upwards to separate the top rails from their slots in the frame.
    • Rotate the lens assembly towards the top of the frame so it sits upright with its cable connectors exposed.
  39. HTC Vive XR Elite Motion Sensor Replacement, Unfasten the lens assembly cables: passo 39, imagem 1 %32
    • Use a T5 Torx screwdriver to remove the four 3.4 mm‑long screws securing the lens assembly cables.
  40. HTC Vive XR Elite Motion Sensor Replacement, Disconnect the lens assembly cables: passo 40, imagem 1 %32 HTC Vive XR Elite Motion Sensor Replacement, Disconnect the lens assembly cables: passo 40, imagem 2 %32 HTC Vive XR Elite Motion Sensor Replacement, Disconnect the lens assembly cables: passo 40, imagem 3 %32
    • Use the flat end of a spudger to pry up and disconnect the lens assembly cable connector.
    • Repeat this procedure for the other connector.
    • To re-attach press connectors like this one, carefully align and press down on one side until it clicks into place, then repeat on the other side. Don't press down on the middle. If the connector is misaligned, the pins can bend, causing permanent damage.
  41. HTC Vive XR Elite Motion Sensor Replacement, Remove the lens assembly: passo 41, imagem 1 %32 HTC Vive XR Elite Motion Sensor Replacement, Remove the lens assembly: passo 41, imagem 2 %32
    • Lift up and remove the lens assembly.
  42. HTC Vive XR Elite Motion Sensor Replacement, Reassembly information: passo 42, imagem 1 %32 HTC Vive XR Elite Motion Sensor Replacement, Reassembly information: passo 42, imagem 2 %32 HTC Vive XR Elite Motion Sensor Replacement, Reassembly information: passo 42, imagem 3 %32
    • The next four steps demonstrate how to secure the lens assembly to the frame during reassembly.
    • In order for the lens assembly to rest in the frame properly, it needs to align with a peg in the IPD (interpupillary distance) slider.
    • Before reinstalling the lens assembly, push the IPD slider to its right-most position.
  43. HTC Vive XR Elite Motion Sensor Replacement: passo 43, imagem 1 %32 HTC Vive XR Elite Motion Sensor Replacement: passo 43, imagem 2 %32 HTC Vive XR Elite Motion Sensor Replacement: passo 43, imagem 3 %32
    • Pull the lens assembly outward until its plastic clips sit close to the end of the top rails.
    • You may need to push and pull the top rail so it sits evenly across the plastic clips.
  44. HTC Vive XR Elite Motion Sensor Replacement: passo 44, imagem 1 %32 HTC Vive XR Elite Motion Sensor Replacement: passo 44, imagem 2 %32 HTC Vive XR Elite Motion Sensor Replacement: passo 44, imagem 3 %32
    • Push the bottom rails inwards as far as they will go.
  45. HTC Vive XR Elite Motion Sensor Replacement: passo 45, imagem 1 %32 HTC Vive XR Elite Motion Sensor Replacement: passo 45, imagem 2 %32 HTC Vive XR Elite Motion Sensor Replacement: passo 45, imagem 3 %32
    • To secure the lens assembly into the frame:
    • Slide the top left rail into its slot.
    • Align the other rails.
    • Press the lens assembly into place, making sure to realign the center peg.
  46. HTC Vive XR Elite Motion Sensor Replacement, Peel the tape: passo 46, imagem 1 %32 HTC Vive XR Elite Motion Sensor Replacement, Peel the tape: passo 46, imagem 2 %32 HTC Vive XR Elite Motion Sensor Replacement, Peel the tape: passo 46, imagem 3 %32
    • Peel off the yellow tape covering the motion sensor cable.
  47. HTC Vive XR Elite Motion Sensor Replacement, Unfasten the motion sensor: passo 47, imagem 1 %32
    • Use a T5 Torx screwdriver to remove the two 3.4 mm‑long screws securing the motion sensor.
  48. HTC Vive XR Elite Motion Sensor Replacement, Reposition the motion sensor: passo 48, imagem 1 %32 HTC Vive XR Elite Motion Sensor Replacement, Reposition the motion sensor: passo 48, imagem 2 %32 HTC Vive XR Elite Motion Sensor Replacement, Reposition the motion sensor: passo 48, imagem 3 %32
    • Don't try to fully remove the motion sensor yet, as it's still connected by a cable.
    • Lift the motion sensor off its pegs in the frame.
    • Flip over the motion sensor and lay it on the frame before continuing.
  49. HTC Vive XR Elite Motion Sensor Replacement, Peel the tape: passo 49, imagem 1 %32 HTC Vive XR Elite Motion Sensor Replacement, Peel the tape: passo 49, imagem 2 %32
    • Peel off the yellow tape covering the motion sensor cable connector.
  50. HTC Vive XR Elite Motion Sensor Replacement, Disconnect the motion sensor: passo 50, imagem 1 %32 HTC Vive XR Elite Motion Sensor Replacement, Disconnect the motion sensor: passo 50, imagem 2 %32
    • Use the point of a spudger to lift up the locking flap on the motion sensor ZIF connector.
  51. HTC Vive XR Elite Motion Sensor Replacement, Remove the motion sensor: passo 51, imagem 1 %32 HTC Vive XR Elite Motion Sensor Replacement, Remove the motion sensor: passo 51, imagem 2 %32
    • Use tweezers to pull the motion sensor cable connector out of its slot.
    • Remove the motion sensor.
Conclusão
Repair didn’t go as planned? Try some basic troubleshooting, or ask our Answers Community for help.
Alex Diaz-Kokaisl
Membro desde: 01/16/22
213.362 Reputação
Autoria de 1.040 guias
Equipe
iFixit Membro de iFixit
Staff
123 Membros
Autoria de 23.639 guias
0Comentários do guia
Comentar
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 2
Últimos 30 dias: 5
Ao todo: 176
