Ir para o conteúdo principal
HTC Vive Pro Motherboard Replacement
O que você precisa
  1. HTC Vive Pro Motherboard Replacement, Reposition the head strap: passo 1, imagem 1 %32 HTC Vive Pro Motherboard Replacement, Reposition the head strap: passo 1, imagem 2 %32
    • Rotate the head strap forward as far as it will go.
  2. HTC Vive Pro Motherboard Replacement, Unplug the All-In-One Cable: passo 2, imagem 1 %32 HTC Vive Pro Motherboard Replacement, Unplug the All-In-One Cable: passo 2, imagem 2 %32
    • Unplug the All-In-One Cable from your headset.
  3. HTC Vive Pro Motherboard Replacement, Remove the All-In-One Cable: passo 3, imagem 1 %32 HTC Vive Pro Motherboard Replacement, Remove the All-In-One Cable: passo 3, imagem 2 %32 HTC Vive Pro Motherboard Replacement, Remove the All-In-One Cable: passo 3, imagem 3 %32
    • Remove the All-In-One Cable from the cable guides along the left side of the head strap.
    • During reassembly, connect the All-In-One Cable to the headset before routing it through the cable guides. This will ensure it has the right amount of slack.
  4. HTC Vive Pro Motherboard Replacement, Remove the top strap: passo 4, imagem 1 %32 HTC Vive Pro Motherboard Replacement, Remove the top strap: passo 4, imagem 2 %32
    • Separate the top strap from itself where the velcro secures it.
  5. HTC Vive Pro Motherboard Replacement: passo 5, imagem 1 %32 HTC Vive Pro Motherboard Replacement: passo 5, imagem 2 %32 HTC Vive Pro Motherboard Replacement: passo 5, imagem 3 %32
    • Peel back the Velcro securing the rear of the top strap.
    • Feed the top strap out through the head strap to remove it.
  6. HTC Vive Pro Motherboard Replacement: passo 6, imagem 1 %32 HTC Vive Pro Motherboard Replacement: passo 6, imagem 2 %32 HTC Vive Pro Motherboard Replacement: passo 6, imagem 3 %32
    • Feed the top strap through the clip on the headset to fully remove it.
  7. HTC Vive Pro Motherboard Replacement, Remove the front side foam pads: passo 7, imagem 1 %32 HTC Vive Pro Motherboard Replacement, Remove the front side foam pads: passo 7, imagem 2 %32 HTC Vive Pro Motherboard Replacement, Remove the front side foam pads: passo 7, imagem 3 %32
    • Peel off both front side foam pads to uncover the speaker wires.
  8. HTC Vive Pro Motherboard Replacement, Remove two rubber spacers: passo 8, imagem 1 %32 HTC Vive Pro Motherboard Replacement, Remove two rubber spacers: passo 8, imagem 2 %32 HTC Vive Pro Motherboard Replacement, Remove two rubber spacers: passo 8, imagem 3 %32
    • Insert the pointed end of your spudger behind the square rubber spacer next to each headphone screw.
    • Gently pry the rubber spacers out of the head strap.
    • Be careful not to accidentally pry any of the speaker wires under the rubber spacer.
  9. HTC Vive Pro Motherboard Replacement, Disconnect the speaker wires: passo 9, imagem 1 %32 HTC Vive Pro Motherboard Replacement, Disconnect the speaker wires: passo 9, imagem 2 %32
    • Use the pointed end of your spudger to pry up and disconnect both the left and right headphone speaker wires.
  10. HTC Vive Pro Motherboard Replacement, Remove the head strap: passo 10, imagem 1 %32 HTC Vive Pro Motherboard Replacement, Remove the head strap: passo 10, imagem 2 %32
    • Use a T6 Torx screwdriver to remove the two 12.1 mm screws (one on each side) securing the head strap to the headset.
    • Use a T5 Torx screwdriver to remove the following screws securing the head strap to the headset:
    • Four 3.9 mm screws (two on each side)
    • Two 4.1 mm screws (one on each side)
  11. HTC Vive Pro Motherboard Replacement: passo 11, imagem 1 %32
    • Remove the two plastic spacers underneath the previously removed screws from the headset.
  12. HTC Vive Pro Motherboard Replacement: passo 12, imagem 1 %32 HTC Vive Pro Motherboard Replacement: passo 12, imagem 2 %32 HTC Vive Pro Motherboard Replacement: passo 12, imagem 3 %32
    • Thread the headphone speaker wires out through the ends of the head strap.
  13. HTC Vive Pro Motherboard Replacement, Remove the outer shell: passo 13, imagem 1 %32 HTC Vive Pro Motherboard Replacement, Remove the outer shell: passo 13, imagem 2 %32 HTC Vive Pro Motherboard Replacement, Remove the outer shell: passo 13, imagem 3 %32
    • The four screws securing the outer shell are covered with black stickers. If the stickers are difficult to remove, simply press your T6 Torx driver through them.
  14. HTC Vive Pro Motherboard Replacement: passo 14, imagem 1 %32 HTC Vive Pro Motherboard Replacement: passo 14, imagem 2 %32
    • Use a T6 Torx screwdriver to remove the four 3.9 mm screws (two on top, two on bottom) securing the outer shell to the headset.
  15. HTC Vive Pro Motherboard Replacement: passo 15, imagem 1 %32 HTC Vive Pro Motherboard Replacement: passo 15, imagem 2 %32 HTC Vive Pro Motherboard Replacement: passo 15, imagem 3 %32
    • Insert an opening pick into the crease between the two halves of the outer shell.
    • Slide the opening pick through the crease to dislodge the clips securing it to the headset.
    • Only insert the opening pick as far as necessary. There are ribbon cables underneath the outer shell.
    • Continue sliding the opening pick through each crease until all clips have been dislodged.
  16. HTC Vive Pro Motherboard Replacement: passo 16, imagem 1 %32 HTC Vive Pro Motherboard Replacement: passo 16, imagem 2 %32 HTC Vive Pro Motherboard Replacement: passo 16, imagem 3 %32
    • Carefully slide each half of the outer shell off of the sensor array.
    • Use caution not to snag any of the ribbon cables underneath.
  17. HTC Vive Pro Motherboard Replacement, Remove the facerest cushion: passo 17, imagem 1 %32 HTC Vive Pro Motherboard Replacement, Remove the facerest cushion: passo 17, imagem 2 %32 HTC Vive Pro Motherboard Replacement, Remove the facerest cushion: passo 17, imagem 3 %32
    • Use your fingers to gently peel the facerest cushion off of the headset.
  18. HTC Vive Pro Motherboard Replacement, Remove the facerest: passo 18, imagem 1 %32 HTC Vive Pro Motherboard Replacement, Remove the facerest: passo 18, imagem 2 %32
    • Partially separate the facerest and the sensor array to access the daughterboard.
  19. HTC Vive Pro Motherboard Replacement: passo 19, imagem 1 %32 HTC Vive Pro Motherboard Replacement: passo 19, imagem 2 %32
    Ferramenta utilizada nesse passo:
    Comprar
    • Use a pair of tweezers to remove the Kapton tape covering the white and purple wires on the daughterboard.
  20. HTC Vive Pro Motherboard Replacement: passo 20, imagem 1 %32 HTC Vive Pro Motherboard Replacement: passo 20, imagem 2 %32 HTC Vive Pro Motherboard Replacement: passo 20, imagem 3 %32
    • Use the pointed end of a spudger to pry up and disconnect the purple and white wires from the daughterboard.
    • Use caution when disconnecting these wires. If you pry up too hard, they may pull out of the connector.
  21. HTC Vive Pro Motherboard Replacement: passo 21, imagem 1 %32 HTC Vive Pro Motherboard Replacement: passo 21, imagem 2 %32
    • Slide the facerest out of the front assembly.
  22. HTC Vive Pro Motherboard Replacement, Remove the sensor array: passo 22, imagem 1 %32 HTC Vive Pro Motherboard Replacement, Remove the sensor array: passo 22, imagem 2 %32
    Comprar
    • Use a pair of tweezers to remove the Kapton tape covering the ZIF connector on the daughterboard.
  23. HTC Vive Pro Motherboard Replacement: passo 23, imagem 1 %32 HTC Vive Pro Motherboard Replacement: passo 23, imagem 2 %32 HTC Vive Pro Motherboard Replacement: passo 23, imagem 3 %32
    • Use the pointed end of a spudger to flip up the locking flap on the daughterboard ZIF connector.
    • Use a pair of tweezers to slide the ribbon cable out of its socket.
  24. HTC Vive Pro Motherboard Replacement: passo 24, imagem 1 %32 HTC Vive Pro Motherboard Replacement: passo 24, imagem 2 %32
    • Use a pair of tweezers to peel back the grey tape covering the ZIF connector on the motherboard underneath the sensor array.
  25. HTC Vive Pro Motherboard Replacement: passo 25, imagem 1 %32 HTC Vive Pro Motherboard Replacement: passo 25, imagem 2 %32 HTC Vive Pro Motherboard Replacement: passo 25, imagem 3 %32
    • Use the flat end of your spudger to flip up the locking flap for the ZIF connector on the motherboard.
    • Use the pointed end of your spudger to disconnect the ribbon cable from the motherboard.
  26. HTC Vive Pro Motherboard Replacement: passo 26, imagem 1 %32 HTC Vive Pro Motherboard Replacement: passo 26, imagem 2 %32
    • Use a T5 Torx screwdriver to remove the four 3.0 mm silver screws securing the sensor array to the lens and OLED assembly.
    • Use a T6 Torx screwdriver to remove the four black 3.8 mm screws securing the sensor array.
  27. HTC Vive Pro Motherboard Replacement: passo 27, imagem 1 %32 HTC Vive Pro Motherboard Replacement: passo 27, imagem 2 %32
    • Lift the sensor array straight up off of the lens and OLED assembly.
  28. HTC Vive Pro Motherboard Replacement, Disconnect the motherboard from the sensor array: passo 28, imagem 1 %32 HTC Vive Pro Motherboard Replacement, Disconnect the motherboard from the sensor array: passo 28, imagem 2 %32
    Comprar
    • Use a pair of tweezers or your fingers to remove the four pieces of Kapton tape covering the ZIF connectors.
  29. HTC Vive Pro Motherboard Replacement: passo 29, imagem 1 %32 HTC Vive Pro Motherboard Replacement: passo 29, imagem 2 %32 HTC Vive Pro Motherboard Replacement: passo 29, imagem 3 %32
    • Use the flat end of your spudger to flip up the locking flap of all four ZIF connectors on the sensor array.
    • Use the pointed end of your spudger to disconnect each ribbon cable from its ZIF connector.
  30. HTC Vive Pro Motherboard Replacement: passo 30, imagem 1 %32 HTC Vive Pro Motherboard Replacement: passo 30, imagem 2 %32
    • Use a pair of tweezers to remove the Kapton tape covering the two ZIF connectors on the back of the motherboard.
  31. HTC Vive Pro Motherboard Replacement: passo 31, imagem 1 %32 HTC Vive Pro Motherboard Replacement: passo 31, imagem 2 %32 HTC Vive Pro Motherboard Replacement: passo 31, imagem 3 %32
    • Use the pointed end of your spudger to unlock the ZIF connector on the back of the motherboard.
    • Slide the ribbon cable out of its socket.
  32. HTC Vive Pro Motherboard Replacement: passo 32, imagem 1 %32 HTC Vive Pro Motherboard Replacement: passo 32, imagem 2 %32 HTC Vive Pro Motherboard Replacement: passo 32, imagem 3 %32
  33. HTC Vive Pro Motherboard Replacement: passo 33, imagem 1 %32 HTC Vive Pro Motherboard Replacement: passo 33, imagem 2 %32
    • Use a pair of tweezers to remove the Kapton tape covering the final ZIF connector on the back of the motherboard.
  34. HTC Vive Pro Motherboard Replacement: passo 34, imagem 1 %32 HTC Vive Pro Motherboard Replacement: passo 34, imagem 2 %32 HTC Vive Pro Motherboard Replacement: passo 34, imagem 3 %32
  35. HTC Vive Pro Motherboard Replacement, Remove the motherboard: passo 35, imagem 1 %32 HTC Vive Pro Motherboard Replacement, Remove the motherboard: passo 35, imagem 2 %32
    • Reposition the long ribbon cable traversing the back of the motherboard so it is out of the way for removal.
    • Do not sharply crease or fold the ribbon cable.
  36. HTC Vive Pro Motherboard Replacement: passo 36, imagem 1 %32
    • Use a T5 Torx screwdriver to remove the three 3.0 mm screws securing the motherboard to the sensor array.
  37. HTC Vive Pro Motherboard Replacement: passo 37, imagem 1 %32
    • Apply a heated iOpener to the back of the motherboard for one minute to soften the light adhesive securing it to the sensor array.
  38. HTC Vive Pro Motherboard Replacement: passo 38, imagem 1 %32
    • Remove the motherboard from the sensor array.
    • There are several plastic clips lightly securing the perimeter of the motherboard to the sensor array.
    • During reassembly, don't forget to reinstall any Kapton tape that was removed during disassembly. This will prevent malfunction of the sensors.
Conclusão
Repair didn’t go as planned? Try some basic troubleshooting, or ask our Valve Index Answers community for help.
Sam Omiotek
Membro desde: 02/25/19
73.429 Reputação
Autoria de 288 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 5
Últimos 30 dias: 13
Duração total: 453
