Ir para o conteúdo principal
HTC Vive Head Strap Replacement
O que você precisa
  1. HTC Vive Head Strap Replacement, Release the upper head strap: passo 1, imagem 1 %32 HTC Vive Head Strap Replacement, Release the upper head strap: passo 1, imagem 2 %32
    • Be sure to power down and disconnect your Vive before beginning.
    • Pull the hook-and-loop (Velcro) closure at the top of the head strap apart to release the top of the head strap.
    Pergunte ao FixBot
    Comentar
  2. HTC Vive Head Strap Replacement, Remove the upper head strap: passo 2, imagem 1 %32 HTC Vive Head Strap Replacement, Remove the upper head strap: passo 2, imagem 2 %32
    • Slide the top part of the head strap through its metal loop on the headset to remove it.
    Pergunte ao FixBot
    Comentar
  3. HTC Vive Head Strap Replacement, Remove the right side of the head strap: passo 3, imagem 1 %32 HTC Vive Head Strap Replacement, Remove the right side of the head strap: passo 3, imagem 2 %32 HTC Vive Head Strap Replacement, Remove the right side of the head strap: passo 3, imagem 3 %32
    • Pull the hook-and-loop closure at the right side of the head strap apart to release the right side of the head strap.
    • Slide the right side of the head strap through its metal loop to remove it.
    Pergunte ao FixBot
    Comentar
  4. HTC Vive Head Strap Replacement, Remove the left side of the head strap: passo 4, imagem 1 %32 HTC Vive Head Strap Replacement, Remove the left side of the head strap: passo 4, imagem 2 %32 HTC Vive Head Strap Replacement, Remove the left side of the head strap: passo 4, imagem 3 %32
    • Pull the hook-and-loop closure at the left side of the head strap apart to release the left side of the head strap.
    • Slide the left side of the head strap through its metal loop to remove it.
    Pergunte ao FixBot
    Comentar
  5. HTC Vive Head Strap Replacement, Remove the head strap: passo 5, imagem 1 %32 HTC Vive Head Strap Replacement, Remove the head strap: passo 5, imagem 2 %32 HTC Vive Head Strap Replacement, Remove the head strap: passo 5, imagem 3 %32
    • Slide the head strap along the cable, away from the Vive.
    • When the head strap comes to the end of the cable, gently slide it over the plugs and remove it.
    Pergunte ao FixBot
    Comentar
Conclusão
6 outras pessoas executaram este guia.
Adam O'Camb
Membro desde: 04/11/15
223.453 Reputação
Autoria de 416 guias
3Comentários do guia
What is the name of the Part that holds the strap and has VIVE written on it ? Can I order that part individually ?
Elias - Responder Compartilhar
You can find that part, as well as the center strap holder by searching on eBay for HTC Vive headset parts. I’ve attached a link here: https://www.ebay.com/itm/Genuine-HTC-VIV...
Ryan Stargell - Responder Compartilhar
how to fix my headset strap on my vive i nead some help on it can you show me how.
GreggTHhompson - Responder Compartilhar
Comentar
Visualizações:
Últimas 24 horas: 4
Últimos 7 dias: 21
Últimos 30 dias: 84
Ao todo: 7,687
