Ir para o conteúdo principal
HTC Vive Focus Rear Head Strap Replacement
O que você precisa
  1. HTC Vive Focus Rear Head Strap Replacement, Unscrew the head strap mounts: passo 1, imagem 1 %32 HTC Vive Focus Rear Head Strap Replacement, Unscrew the head strap mounts: passo 1, imagem 2 %32
    • Use a T6 Torx screwdriver to remove the four 4.6 mm screws securing the rear head strap, two on each side.
  2. HTC Vive Focus Rear Head Strap Replacement, Disconnect the rear head strap: passo 2, imagem 1 %32 HTC Vive Focus Rear Head Strap Replacement, Disconnect the rear head strap: passo 2, imagem 2 %32 HTC Vive Focus Rear Head Strap Replacement, Disconnect the rear head strap: passo 2, imagem 3 %32
    • Remove the plastic cover from the rear head strap mount.
    • Lift the rear head strap off of the two pegs securing it to the mount.
    • Repeat for the remaining side of the rear head strap.
    • During reassembly, be careful not to install the rear head strap upside-down. The adjustment knob on the back of the head strap should be on top.
  3. HTC Vive Focus Rear Head Strap Replacement, Remove the rear head strap: passo 3, imagem 1 %32
    • Remove the rear head strap.
Conclusão
Sam Omiotek
Membro desde: 02/25/19
73.690 Reputação
Autoria de 288 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 2
Últimos 7 dias: 5
Últimos 30 dias: 9
Duração total: 169
