Ir para o conteúdo principal
HTC Vive Focus Facerest Replacement
O que você precisa
  1. HTC Vive Focus Facerest Replacement, Remove the facerest cushion: passo 1, imagem 1 %32 HTC Vive Focus Facerest Replacement, Remove the facerest cushion: passo 1, imagem 2 %32 HTC Vive Focus Facerest Replacement, Remove the facerest cushion: passo 1, imagem 3 %32
    • Place your device upside-down on your work surface.
    • The facerest cushion is lightly held into place by seven plastic clips.
    • Use your fingers to gently pull the facerest cushion straight off of the facerest to remove it.
  2. HTC Vive Focus Facerest Replacement, Remove the facerest: passo 2, imagem 1 %32
    • Use a T5 Torx screwdriver to remove the eight 4.5 mm screws securing the facerest.
    • One of the screws will be covered by a tamper-evident sticker. Press the driver through the sticker to remove the screw.
  3. HTC Vive Focus Facerest Replacement: passo 3, imagem 1 %32 HTC Vive Focus Facerest Replacement: passo 3, imagem 2 %32 HTC Vive Focus Facerest Replacement: passo 3, imagem 3 %32
    • Insert an opening pick into the upper-left corner of the facerest.
    • Twist the opening pick to release the plastic clip securing the facerest.
    • Repeat for the upper-right corner.
    • Don't remove the facerest yet. It's still attached by the facerest sensor ribbon cable.
  4. HTC Vive Focus Facerest Replacement, Remove the facerest sensor: passo 4, imagem 1 %32 HTC Vive Focus Facerest Replacement, Remove the facerest sensor: passo 4, imagem 2 %32 HTC Vive Focus Facerest Replacement, Remove the facerest sensor: passo 4, imagem 3 %32
    • Carefully flip your device over.
    • Pull the facerest out just enough to access the screws securing the facerest sensor.
    • Don't put any strain on the facerest sensor ribbon cable.
    • During reassembly, make sure the facerest sensor ribbon cable is positioned between the lenses before reinstalling the facerest.
  5. HTC Vive Focus Facerest Replacement: passo 5, imagem 1 %32
    • Use a T5 Torx screwdriver to remove the two 2.4 mm screws securing the facerest sensor to the facerest.
  6. HTC Vive Focus Facerest Replacement: passo 6, imagem 1 %32
    • Remove the facerest.
Conclusão
Sam Omiotek
Membro desde: 02/25/19
73.741 Reputação
Autoria de 288 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 5
Últimos 30 dias: 11
Duração total: 94
