Ir para o conteúdo principal
HTC Trophy Motherboard Replacement
O que você precisa
  1. HTC Trophy Motherboard Replacement, Battery: passo 1, imagem 1 %32 HTC Trophy Motherboard Replacement, Battery: passo 1, imagem 2 %32 HTC Trophy Motherboard Replacement, Battery: passo 1, imagem 3 %32
    • Power off the phone before starting.
    • Remove the back panel by inserting the IFixIt opening tool into gap at the top of the rear and prying upward.
    Pergunte ao FixBot
    Comentar
  2. HTC Trophy Motherboard Replacement: passo 2, imagem 1 %32 HTC Trophy Motherboard Replacement: passo 2, imagem 2 %32 HTC Trophy Motherboard Replacement: passo 2, imagem 3 %32
    • Remove the battery by inserting the IFixIt opening tool into the small gap between the battery and the surrounding plastic.
    • Apply a small force towards the bottom of the phone and lift upwards.
    • Be careful not to puncture the battery.
    Pergunte ao FixBot
    Comentar
  3. HTC Trophy Motherboard Replacement, Display Assembly: passo 3, imagem 1 %32 HTC Trophy Motherboard Replacement, Display Assembly: passo 3, imagem 2 %32 HTC Trophy Motherboard Replacement, Display Assembly: passo 3, imagem 3 %32
    • Remove the 5 screws holding the two phone halves together.
    • Three 4mm long T5 Torx screws.
    • Press a T5 Torx screwdriver into the void sticker and remove the 4mm long T5 Torx screw.
    • One 4mm long Philips #000 screw.
    • Remove the installed SIM card if one is present.
    Pergunte ao FixBot
    Comentar
  4. HTC Trophy Motherboard Replacement: passo 4, imagem 1 %32 HTC Trophy Motherboard Replacement: passo 4, imagem 2 %32 HTC Trophy Motherboard Replacement: passo 4, imagem 3 %32
    • Insert the IFixIt opening tool into the seem of the plastic around the edge of the phone and pry the two halves apart.
    • There are small plastic clips holding the phone together. Slide the opening tool around the edge until it clicks apart to avoid damage.
    • The volume button will fall out when the phone is opened.
    • The black sticker beneath the battery will rip once the phone is separated.
    Pergunte ao FixBot
    Comentar
  5. HTC Trophy Motherboard Replacement: passo 5, imagem 1 %32 HTC Trophy Motherboard Replacement: passo 5, imagem 2 %32 HTC Trophy Motherboard Replacement: passo 5, imagem 3 %32
    • Remove the three screws holding the mother board to the display assembly.
    • One 2mm long Philips #000 screw.
    • Two 4mm long T5 Torx screws in the holes of the plastic.
    Pergunte ao FixBot
    Comentar
  6. HTC Trophy Motherboard Replacement: passo 6, imagem 1 %32 HTC Trophy Motherboard Replacement: passo 6, imagem 2 %32 HTC Trophy Motherboard Replacement: passo 6, imagem 3 %32
    Ferramenta utilizada neste passo:
    • Remove the black tape cover the ribbon cable connectors with tweezers.
    • Disconnect the ribbon cables from the connectors.
    • Ribbon cables are extremely fragile.
    Pergunte ao FixBot
    Comentar
  7. HTC Trophy Motherboard Replacement: passo 7, imagem 1 %32 HTC Trophy Motherboard Replacement: passo 7, imagem 2 %32
    • Remove power button from the top of the phone with tweezers.
    Pergunte ao FixBot
    Comentar
  8. HTC Trophy Motherboard Replacement: passo 8, imagem 1 %32 HTC Trophy Motherboard Replacement: passo 8, imagem 2 %32 HTC Trophy Motherboard Replacement: passo 8, imagem 3 %32
    • Use the iFixit opening tool to separate the motherboard from the display assembly.
    Pergunte ao FixBot
    Comentar
  9. HTC Trophy Motherboard Replacement, Motherboard: passo 9, imagem 1 %32 HTC Trophy Motherboard Replacement, Motherboard: passo 9, imagem 2 %32 HTC Trophy Motherboard Replacement, Motherboard: passo 9, imagem 3 %32
    • Remove the plastic piece off of the motherboard.
    • Put pressure outwards to release these clips with the iFixit opening tool and you fingers.
    Pergunte ao FixBot
    Comentar
Conclusão
Always dispose of e-waste properly. Follow this guide on how to dispose of the old motherboard.
Uma outra pessoa concluiu este guia.
0Comentários do guia
Comentar
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 14
Últimos 30 dias: 35
Ao todo: 496
