Ir para o conteúdo principal
HTC Thunderbolt Volume Buttons Replacement
O que você precisa
  1. HTC Thunderbolt Volume Buttons Replacement, Rear Panel: passo 1, imagem 1 %32
    • Insert the plastic opening tool into the top of the Thunderbolt near the power button.
    • Gently pry up on the rear panel around the edges until it is loose.
    Pergunte ao FixBot
    Comentar
  2. HTC Thunderbolt Volume Buttons Replacement: passo 2, imagem 1 %32
    • Lift and remove the rear panel.
    Pergunte ao FixBot
    Comentar
  3. HTC Thunderbolt Volume Buttons Replacement, Battery: passo 3, imagem 1 %32 HTC Thunderbolt Volume Buttons Replacement, Battery: passo 3, imagem 2 %32
    • Using the plastic opening tool, lift up the battery from the bottom near the kickstand.
    • Remove the battery from the inner frame.
    Pergunte ao FixBot
    Comentar
  4. HTC Thunderbolt Volume Buttons Replacement, MicroSD Card: passo 4, imagem 1 %32 HTC Thunderbolt Volume Buttons Replacement, MicroSD Card: passo 4, imagem 2 %32
    • Use your finger to push the MicroSD card in towards the top of the phone, allowing it to be released from the casing.
    Pergunte ao FixBot
    Comentar
  5. HTC Thunderbolt Volume Buttons Replacement: passo 5, imagem 1 %32
    Ferramenta utilizada neste passo:
    • Use tweezers to grab onto the MicroSD card and carefully remove it from the casing.
    Pergunte ao FixBot
    Comentar
  6. HTC Thunderbolt Volume Buttons Replacement, Rear Frame: passo 6, imagem 1 %32
    • Remove the six Phillips screws from the perimeter of the rear frame.
    • By removing the screw with the "void" sticker on it, your Thunderbolt will no longer be covered under warranty.
    Pergunte ao FixBot
    Comentar
  7. HTC Thunderbolt Volume Buttons Replacement: passo 7, imagem 1 %32 HTC Thunderbolt Volume Buttons Replacement: passo 7, imagem 2 %32
    • Insert the plastic opening tool into the bottom of the phone underneath the soft keys.
    • Gently pry up on the plastic cover by sliding the plastic opening tool across the bottom of the phone.
    • Remove the plastic cover.
    • The plastic cover will have adhesive on it making it difficult to remove.
    Pergunte ao FixBot
    Comentar
  8. HTC Thunderbolt Volume Buttons Replacement: passo 8, imagem 1 %32
    • Remove the two Phillips screws where the plastic cover was.
    Pergunte ao FixBot
    Comentar
  9. HTC Thunderbolt Volume Buttons Replacement: passo 9, imagem 1 %32 HTC Thunderbolt Volume Buttons Replacement: passo 9, imagem 2 %32
    • Insert the plastic opening tool in between the screen and the frame on the side of the phone.
    • Slowly slide the the plastic opening tool along the side of the phone until the screen begins to separate from the frame.
    • Do the same for the opposite side of the phone.
    Pergunte ao FixBot
    Comentar
  10. HTC Thunderbolt Volume Buttons Replacement: passo 10, imagem 1 %32 HTC Thunderbolt Volume Buttons Replacement: passo 10, imagem 2 %32 HTC Thunderbolt Volume Buttons Replacement: passo 10, imagem 3 %32
    • Carefully separate the screen and phone from the rear frame, starting from the bottom.
    • Gently pull down on the phone and screen to fully separate it from the rear frame.
    Pergunte ao FixBot
    Comentar
  11. HTC Thunderbolt Volume Buttons Replacement, Volume Buttons: passo 11, imagem 1 %32
    • Locate the side volume buttons
    Pergunte ao FixBot
    Comentar
  12. HTC Thunderbolt Volume Buttons Replacement: passo 12, imagem 1 %32 HTC Thunderbolt Volume Buttons Replacement: passo 12, imagem 2 %32
    • Use a pry tool to lift the buttons out of the case
    Pergunte ao FixBot
    Comentar
Conclusão
Vanessa
Membro desde: 01/18/13
60 Reputação
Autoria de 4 guias
Equipe
Cal Poly, Team 19-45, Regan Winter 2013 Membro de Cal Poly, Team 19-45, Regan Winter 2013
CPSU-REGAN-W13S19G45
4 Membros
Autoria de 24 guias
0Comentários do guia
Comentar
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 7
Últimos 30 dias: 41
Ao todo: 943
