Este guia tem alterações mais recentes. Mudar para a última versão não verificada.
Introdução
The display screen is protected behind the exterior plastic case of the phone.
O que você precisa
Insert your finger or a pry tool into the slot above the battery. Remove it and set aside.
To remove the case, use a small, pentagonal screwdriver to unscrew the 6 screws that can be found around the edges.
Next, unscrew the top screw using a small, Philips screwdriver.
Pull back the motherboard.
Using a spudger, remove the display screen from its cell within the front case. Insert the spudger next to the LCD on the opposite side of where the motherboard is attached.
Uma outra pessoa concluiu este guia.
