Esta versão pode conter edições incorretas. Mude para o último instantâneo verificado.
O que você precisa
Este passo não foi traduzido. Ajude a traduzi-lo
First, flip the phone over so that the back is facing upwards.
Using both thumbs, push the back side of the phone's exterior up and remove the front face of the phone.
Insert your finger or a pry tool into the slot above the battery. Remove it and set aside.
To remove the case, use a small, pentagonal screwdriver to unscrew the 6 screws that can be found around the edges.
Next, unscrew the top screw using a small, Philips screwdriver.
Pull back the motherboard.
Using a spudger, remove the display screen from its cell within the front case. Insert the spudger next to the LCD on the opposite side of where the motherboard is attached.
Place the motherboard down on top of the LCD. Using tweezers, remove the yellow piece of tape covering the end of the flat ribbon cable.
Peel off the silver tape covering the flat ribbon cable. The motherboard is now free from the rest of the phone.
Uma outra pessoa concluiu este guia.
