Ir para o conteúdo principal
HTC Rhyme Volume Button Replacement
O que você precisa
  1. HTC Rhyme Volume Button  Replacement, Removing Back Cover: passo 1, imagem 1 %32
    • Slide the bottom back cover off of the phone.
    Pergunte ao FixBot
    Comentar
  2. HTC Rhyme Volume Button  Replacement: passo 2, imagem 1 %32
    • Locate the four screws on the plastic cover and unscrew them.
    Pergunte ao FixBot
    Comentar
  3. HTC Rhyme Volume Button  Replacement: passo 3, imagem 1 %32
    • Pry the sticker off from the sides.
    • You can use a metal spudger to do this.
    • Peel the sticker off with your hands.
    Pergunte ao FixBot
    Comentar
  4. HTC Rhyme Volume Button  Replacement, Remove the plastic cover: passo 4, imagem 1 %32
    • Remove the plastic cover using your hands.
    Pergunte ao FixBot
    Comentar
  5. HTC Rhyme Volume Button  Replacement: passo 5, imagem 1 %32
    • Remove the yellow ribbon.
    Pergunte ao FixBot
    Comentar
  6. HTC Rhyme Volume Button  Replacement: passo 6, imagem 1 %32 HTC Rhyme Volume Button  Replacement: passo 6, imagem 2 %32 HTC Rhyme Volume Button  Replacement: passo 6, imagem 3 %32
    • Lift up the blue flaps underneath the battery.
    • Lift up the black flap at the top of the phone.
    • Lift up the black flap at the bottom of the phone.
    Pergunte ao FixBot
    Comentar
  7. HTC Rhyme Volume Button  Replacement, Remove the Motherboard: passo 7, imagem 1 %32 HTC Rhyme Volume Button  Replacement, Remove the Motherboard: passo 7, imagem 2 %32
    • Remove all 4 screws.
    • Carefully remove the motherboard with your hands.
    Pergunte ao FixBot
    Comentar
  8. HTC Rhyme Volume Button  Replacement, Removing the back plastic casing: passo 8, imagem 1 %32 HTC Rhyme Volume Button  Replacement, Removing the back plastic casing: passo 8, imagem 2 %32 HTC Rhyme Volume Button  Replacement, Removing the back plastic casing: passo 8, imagem 3 %32
    • Pry the back plastic casing off with your hands.
    Pergunte ao FixBot
    Comentar
  9. HTC Rhyme Volume Button  Replacement: passo 9, imagem 1 %32 HTC Rhyme Volume Button  Replacement: passo 9, imagem 2 %32
    • Use the tip of a screwdriver to push the button out of the panel.
    Pergunte ao FixBot
    Comentar
Conclusão
Frederick
Membro desde: 10/08/14
119 Reputação
Autoria de 1 guia
Equipe
USF Tampa, Team 9-6, Leahy Fall 2014 Membro de USF Tampa, Team 9-6, Leahy Fall 2014
USFT-LEAHY-F14S9G6
3 Membros
Autoria de 10 guias
0Comentários do guia
Comentar
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 4
Últimos 30 dias: 21
Ao todo: 471
