Ir para o conteúdo principal
HTC Rezound Screen Replacement
O que você precisa
  1. HTC Rezound Screen  Replacement, Battery: passo 1, imagem 1 %32
    • Use a plastic opening tool or your fingers to get into the groove between the cover and case. Remove the back covering so that the red battery is visible.
    Pergunte ao FixBot
    Comentar
  2. HTC Rezound Screen  Replacement: passo 2, imagem 1 %32
    • Remove the red battery to replace.
    Pergunte ao FixBot
    Comentar
  3. HTC Rezound Screen  Replacement, Screen: passo 3, imagem 1 %32 HTC Rezound Screen  Replacement, Screen: passo 3, imagem 2 %32 HTC Rezound Screen  Replacement, Screen: passo 3, imagem 3 %32
    • Unscrew the six screws (Torx T4 size) shown in the photo.
    • Use the spudger to pry the casing off of the phone.
    Pergunte ao FixBot
    Comentar
  4. HTC Rezound Screen  Replacement: passo 4, imagem 1 %32 HTC Rezound Screen  Replacement: passo 4, imagem 2 %32
    • Gently remove the casing from the phone.
    Pergunte ao FixBot
    Comentar
  5. HTC Rezound Screen  Replacement: passo 5, imagem 1 %32
    • After the red casing is removed, the following components should be visible:
    • Main Camera
    • Headphone Jack
    • Vibration moter
    Pergunte ao FixBot
    Comentar
  6. HTC Rezound Screen  Replacement: passo 6, imagem 1 %32 HTC Rezound Screen  Replacement: passo 6, imagem 2 %32
    • Remove the 2 screws (Torx T7 size), which are located on the upper left and lower right sides of the device.
    Pergunte ao FixBot
    Comentar
  7. HTC Rezound Screen  Replacement: passo 7, imagem 1 %32 HTC Rezound Screen  Replacement: passo 7, imagem 2 %32 HTC Rezound Screen  Replacement: passo 7, imagem 3 %32
    Ferramenta utilizada neste passo:
    • Using tweezers, flip the latch on the ribbon cables connecting the logic board to the screen and display. The screen and display for the HTC Rezound are likely fused to one another, so if you are replacing one you will likely need to replace both of them.
    • At this point all that's left is to insert the ribbon cables of your replacement into the same slot on the motherboard!
    Pergunte ao FixBot
    Comentar
Conclusão
Bridgette Mellon
Membro desde: 01/29/18
243 Reputação
Autoria de 2 guias
0Comentários do guia
Comentar
Visualizações:
Últimas 24 horas: 1
Últimos 7 dias: 7
Últimos 30 dias: 34
Ao todo: 620
