Ir para o conteúdo principal
HTC One X Plus Screen Replacement
O que você precisa
  1. HTC One X Plus Screen Replacement, Screen: passo 1, imagem 1 %32
    • Power off your device.
    • Insert a pin, paper clip, or very small piece of metal in the hole next to the micro sim card holder to remove it.
    • The sim card slot is located on the top edge of the device.
    Pergunte ao FixBot
    Comentar
  2. HTC One X Plus Screen Replacement: passo 2, imagem 1 %32 HTC One X Plus Screen Replacement: passo 2, imagem 2 %32 HTC One X Plus Screen Replacement: passo 2, imagem 3 %32
    • Using plastic opening tools, pry open the bottom of the device first.
    • You will hear clicking sounds as the sides of the device detach from the screen.
    • Once both sides are detached, use the suction cup tool to remove the screen completely from the black encasing.
    Pergunte ao FixBot
    Comentar
  3. HTC One X Plus Screen Replacement: passo 3, imagem 1 %32 HTC One X Plus Screen Replacement: passo 3, imagem 2 %32 HTC One X Plus Screen Replacement: passo 3, imagem 3 %32
    • Remove the five 2.4 mm screws using a Phillips #000 screwdriver.
    • Remove the plastic cover.
    Pergunte ao FixBot
    Comentar
  4. HTC One X Plus Screen Replacement: passo 4, imagem 1 %32 HTC One X Plus Screen Replacement: passo 4, imagem 2 %32 HTC One X Plus Screen Replacement: passo 4, imagem 3 %32
    • Use a Phillips #000 screwdriver to remove the two 3.4 mm screws.
    • Remove the PCB board and antenna.
    Pergunte ao FixBot
    Comentar
  5. HTC One X Plus Screen Replacement: passo 5, imagem 1 %32 HTC One X Plus Screen Replacement: passo 5, imagem 2 %32
    Ferramenta utilizada neste passo:
    • Use tweezers to disconnect the power button flex cable.
    Pergunte ao FixBot
    Comentar
  6. HTC One X Plus Screen Replacement: passo 6, imagem 1 %32 HTC One X Plus Screen Replacement: passo 6, imagem 2 %32 HTC One X Plus Screen Replacement: passo 6, imagem 3 %32
    • Disconnect the battery's six pin connector from the motherboard.
    • Remove the battery by pulling it upwards.
    Pergunte ao FixBot
    Comentar
  7. HTC One X Plus Screen Replacement: passo 7, imagem 1 %32
    • Disconnect the screen from the digitizer.
    • Use a plastic opening tool to gently disconnect the screen from the digitizer.
    • You may have to use heat to loosen adhesive securing the screen.
    Pergunte ao FixBot
    Comentar
Conclusão
Jason Melo
Membro desde: 08/26/15
483 Reputação
Autoria de 4 guias
Equipe
USF Tampa, Team 3-3, Eyestone Fall 2015 Membro de USF Tampa, Team 3-3, Eyestone Fall 2015
USFT-EYESTONE-F15S3G3
3 Membros
Autoria de 15 guias
1Comentário do guia
Man, this did nothing but break my International One X+. There were so many instructions missing.
Garrett Reyman - Responder Compartilhar
Comentar
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 2
Últimos 30 dias: 35
Ao todo: 2,195
