Ir para o conteúdo principal
HTC One X Plus Antenna Replacement
O que você precisa
  1. HTC One X Plus Antenna Replacement, Antenna: passo 1, imagem 1 %32
    • Power off your device.
    • Insert a pin, paper clip, or very small piece of metal into the hole next to the micro-SIM card holder to remove it.
    • The SIM card slot is located on the top edge of the device.
    Pergunte ao FixBot
    Comentar
  2. HTC One X Plus Antenna Replacement: passo 2, imagem 1 %32 HTC One X Plus Antenna Replacement: passo 2, imagem 2 %32 HTC One X Plus Antenna Replacement: passo 2, imagem 3 %32
    • Using the plastic opening tools, pry open the bottom of the device first.
    • You will hear clicking sounds as the sides of the device detach from the screen.
    • Once both sides are detached, use the suction cup tool to remove the screen completely from the black encasing.
    Pergunte ao FixBot
    Comentar
  3. HTC One X Plus Antenna Replacement: passo 3, imagem 1 %32
    Ferramenta utilizada neste passo:
    • Now that the rear panel has been removed, use the metal tweezers to carefully remove the antenna.
    • The antenna is the loose black wire located to the right of the battery.
    • Using the metal tweezers, connect and install your new antenna, securing the antenna beneath the metal supports.
    Pergunte ao FixBot
    Comentar
Conclusão
Jason Melo
Membro desde: 08/26/15
483 Reputação
Autoria de 4 guias
Equipe
USF Tampa, Team 3-3, Eyestone Fall 2015 Membro de USF Tampa, Team 3-3, Eyestone Fall 2015
USFT-EYESTONE-F15S3G3
3 Membros
Autoria de 10 guias
0Comentários do guia
Comentar
Visualizações:
Últimas 24 horas: 1
Últimos 7 dias: 8
Últimos 30 dias: 26
Ao todo: 939
