Ir para o conteúdo principal
HTC One V Camera Replacement
O que você precisa
  1. HTC One V Camera Replacement, Disassembling HTC ONE V Bottom Assembly: passo 1, imagem 1 %32 HTC One V Camera Replacement, Disassembling HTC ONE V Bottom Assembly: passo 1, imagem 2 %32 HTC One V Camera Replacement, Disassembling HTC ONE V Bottom Assembly: passo 1, imagem 3 %32
    • Power off your device.
    • Remove the bottom cover by sliding it off.
    Pergunte ao FixBot
    Comentar
  2. HTC One V Camera Replacement: passo 2, imagem 1 %32
    • Remove the SIM card.
    • Remove the four screws securing the bottom casing.
    • Two 3.0 mm Phillips #0 screws in the top left and right corners.
    • Two 2.0 mm Phillips #0 screws in the bottom left and right corners.
    Pergunte ao FixBot
    Comentar
  3. HTC One V Camera Replacement: passo 3, imagem 1 %32 HTC One V Camera Replacement: passo 3, imagem 2 %32
    • Remove the 2.0 mm Phillips #0 screws on either side of the phone.
    Pergunte ao FixBot
    Comentar
  4. HTC One V Camera Replacement: passo 4, imagem 1 %32 HTC One V Camera Replacement: passo 4, imagem 2 %32 HTC One V Camera Replacement: passo 4, imagem 3 %32
    • Use a plastic opening tool to pry open the bottom casing.
    • Remove the bottom casing by pulling it towards you.
    Pergunte ao FixBot
    Comentar
  5. HTC One V Camera Replacement, Disassembling HTC One V Back Case: passo 5, imagem 1 %32 HTC One V Camera Replacement, Disassembling HTC One V Back Case: passo 5, imagem 2 %32 HTC One V Camera Replacement, Disassembling HTC One V Back Case: passo 5, imagem 3 %32
    • Use the plastic opening tool to pry open the rear camera panel.
    • Remove both screws that are securing the back case.
    • One 4.0 mm Phillips #0 screw.
    • One 3.0 mm Phillips #0 screw.
    Pergunte ao FixBot
    Comentar
  6. HTC One V Camera Replacement: passo 6, imagem 1 %32 HTC One V Camera Replacement: passo 6, imagem 2 %32 HTC One V Camera Replacement: passo 6, imagem 3 %32
    • Use a Jimmy to pry up the OEM SIM and SD card reader contact.
    • Pry from right to left to avoid potential damages to the ribbon.
    Pergunte ao FixBot
    Comentar
  7. HTC One V Camera Replacement: passo 7, imagem 1 %32 HTC One V Camera Replacement: passo 7, imagem 2 %32 HTC One V Camera Replacement: passo 7, imagem 3 %32
    • Using both thumbs, gently push on the two bottom rear corners of the motherboard.
    • Gently and slowly pull the screen out from the front of the phone, while feeding the OEM reader contact through the opening.
    Pergunte ao FixBot
    Comentar
  8. HTC One V Camera Replacement, Battery: passo 8, imagem 1 %32
    • Pry up the battery with the flat end of the spudger.
    Pergunte ao FixBot
    Comentar
  9. HTC One V Camera Replacement: passo 9, imagem 1 %32 HTC One V Camera Replacement: passo 9, imagem 2 %32 HTC One V Camera Replacement: passo 9, imagem 3 %32
    • Gently lift up the battery away from the edge of its housing.
    • Use the point end of the spudger to push the connection out of its housing.
    Pergunte ao FixBot
    Comentar
  10. HTC One V Camera Replacement, Camera Lens: passo 10, imagem 1 %32 HTC One V Camera Replacement, Camera Lens: passo 10, imagem 2 %32 HTC One V Camera Replacement, Camera Lens: passo 10, imagem 3 %32
    • Remove the two 3.0 mm Phillips #0 screws, that are securing the camera lens.
    Pergunte ao FixBot
    Comentar
  11. HTC One V Camera Replacement: passo 11, imagem 1 %32
    • Pry off the camera lens using a plastic opening tool.
    Pergunte ao FixBot
    Comentar
  12. HTC One V Camera Replacement, Vibrator: passo 12, imagem 1 %32 HTC One V Camera Replacement, Vibrator: passo 12, imagem 2 %32
    Ferramenta utilizada neste passo:
    • Pry the vibrator out of the housing with a spudger.
    • Using the tweezers, pull up on the connecting wires detaching the vibrator from the motherboard.
    Pergunte ao FixBot
    Comentar
  13. HTC One V Camera Replacement, Motherboard: passo 13, imagem 1 %32 HTC One V Camera Replacement, Motherboard: passo 13, imagem 2 %32 HTC One V Camera Replacement, Motherboard: passo 13, imagem 3 %32
    • Using the spudger lift the tabs on the highlighted, red and orange, ribbon connectors. Gently pull out the ribbons from their connectors.
    • Remove the 3.0 mm Phillips #0 screw.
    Pergunte ao FixBot
    Comentar
  14. HTC One V Camera Replacement: passo 14, imagem 1 %32 HTC One V Camera Replacement: passo 14, imagem 2 %32 HTC One V Camera Replacement: passo 14, imagem 3 %32
    • Using tweezers, pull back on the tape located on the bottom corners of the motherboard.
    Pergunte ao FixBot
    Comentar
  15. HTC One V Camera Replacement: passo 15, imagem 1 %32 HTC One V Camera Replacement: passo 15, imagem 2 %32
    • Use the spudger to push back the latch holding on the motherboard. While the latch is pushed back use the plastic opening tool to pry up the motherboard.
    Pergunte ao FixBot
    Comentar
  16. HTC One V Camera Replacement: passo 16, imagem 1 %32
    • Place your phone on its side so that you can gently pull up on the motherboard to expose its last connector.
    • Using the flat end of the spudger, pop of the connector.
    Pergunte ao FixBot
    Comentar
  17. HTC One V Camera Replacement, Camera: passo 17, imagem 1 %32 HTC One V Camera Replacement, Camera: passo 17, imagem 2 %32
    • Flip motherboard over so the backside is up.
    Pergunte ao FixBot
    Comentar
  18. HTC One V Camera Replacement: passo 18, imagem 1 %32 HTC One V Camera Replacement: passo 18, imagem 2 %32
    • Pull the camera back using the tweezers, and hold it.
    • Use the spudger to unlock the camera's ribbon from its connector.
    • Using the tweezers, pull up on the ribbon and release the camera form the motherboard.
    • The ribbon is connected to the back of the LCD display by tape. Slowly pull the ribbon back and the tape will follow.
    Pergunte ao FixBot
    Comentar
Conclusão
Equipe
USF Tampa, Team 1-3, Blackwell Winter 2015 Membro de USF Tampa, Team 1-3, Blackwell Winter 2015
USFT-BLACKWELL-W15S1G3
4 Membros
Autoria de 24 guias
0Comentários do guia
Comentar
Visualizações:
Últimas 24 horas: 1
Últimos 7 dias: 8
Últimos 30 dias: 40
Ao todo: 1,270
