Ir para o conteúdo principal
HTC One V Battery Replacement
O que você precisa
  1. HTC One V Battery Replacement, Disassembling HTC ONE V Bottom Assembly: passo 1, imagem 1 %32 HTC One V Battery Replacement, Disassembling HTC ONE V Bottom Assembly: passo 1, imagem 2 %32 HTC One V Battery Replacement, Disassembling HTC ONE V Bottom Assembly: passo 1, imagem 3 %32
    • Power off your device.
    • Remove the bottom cover by sliding it off.
    Pergunte ao FixBot
    Comentar
  2. HTC One V Battery Replacement: passo 2, imagem 1 %32
    • Remove the SIM card.
    • Remove the four screws securing the bottom casing.
    • Two 3.0 mm Phillips #0 screws in the top left and right corners.
    • Two 2.0 mm Phillips #0 screws in the bottom left and right corners.
    Pergunte ao FixBot
    Comentar
  3. HTC One V Battery Replacement: passo 3, imagem 1 %32 HTC One V Battery Replacement: passo 3, imagem 2 %32
    • Remove the 2.0 mm Phillips #0 screws on either side of the phone.
    Pergunte ao FixBot
    Comentar
  4. HTC One V Battery Replacement: passo 4, imagem 1 %32 HTC One V Battery Replacement: passo 4, imagem 2 %32 HTC One V Battery Replacement: passo 4, imagem 3 %32
    • Use a plastic opening tool to pry open the bottom casing.
    • Remove the bottom casing by pulling it towards you.
    Pergunte ao FixBot
    Comentar
  5. HTC One V Battery Replacement, Disassembling HTC One V Back Case: passo 5, imagem 1 %32 HTC One V Battery Replacement, Disassembling HTC One V Back Case: passo 5, imagem 2 %32 HTC One V Battery Replacement, Disassembling HTC One V Back Case: passo 5, imagem 3 %32
    • Use the plastic opening tool to pry open the rear camera panel.
    • Remove both screws that are securing the back case.
    • One 4.0 mm Phillips #0 screw.
    • One 3.0 mm Phillips #0 screw.
    Pergunte ao FixBot
    Comentar
  6. HTC One V Battery Replacement: passo 6, imagem 1 %32 HTC One V Battery Replacement: passo 6, imagem 2 %32 HTC One V Battery Replacement: passo 6, imagem 3 %32
    • Use a Jimmy to pry up the OEM SIM and SD card reader contact.
    • Pry from right to left to avoid potential damages to the ribbon.
    Pergunte ao FixBot
    Comentar
  7. HTC One V Battery Replacement: passo 7, imagem 1 %32 HTC One V Battery Replacement: passo 7, imagem 2 %32 HTC One V Battery Replacement: passo 7, imagem 3 %32
    • Using both thumbs, gently push on the two bottom rear corners of the motherboard.
    • Gently and slowly pull the screen out from the front of the phone, while feeding the OEM reader contact through the opening.
    Pergunte ao FixBot
    Comentar
  8. HTC One V Battery Replacement, Battery: passo 8, imagem 1 %32
    • Pry up the battery with the flat end of the spudger.
    Pergunte ao FixBot
    Comentar
  9. HTC One V Battery Replacement: passo 9, imagem 1 %32 HTC One V Battery Replacement: passo 9, imagem 2 %32 HTC One V Battery Replacement: passo 9, imagem 3 %32
    • Gently lift up the battery away from the edge of its housing.
    • Use the point end of the spudger to push the connection out of its housing.
    Pergunte ao FixBot
    Comentar
Conclusão
9 outras pessoas executaram este guia.
Equipe
USF Tampa, Team 1-3, Blackwell Winter 2015 Membro de USF Tampa, Team 1-3, Blackwell Winter 2015
USFT-BLACKWELL-W15S1G3
4 Membros
Autoria de 24 guias
5Comentários do guia
Good guide! At step 6 it was easier for me to start pry from felt to right. I'm not sure, but it seems there is 2 ribbons not one, and it maybe I accidentally teared the one on the right. I really not sure, because my speaker still working. Take care! A closer image from the ribbon(s) would help!
Thank you, my phone is working again!
Stoci75 - Responder Compartilhar
Step 6 was difficult because the card reader contact was stuck down with some kind of adhesive
Brian Conolly - Responder Compartilhar
In Step 4, a small rubber block fell out and it took a while to work out where it belongs. You can just make out where it should be in the bottom left of the second photo in Step 4.
Overall, great instructions, and thank you!
Good guide! Actually I skipped step 6 which I felt not required. As sticking it back in position would be problem, so I just tilted the two separated sides & changed the battery.
Thank you , my phone started working again !
uday - Responder Compartilhar
Very well -understood process! Excellent!
Jānis Purmalis - Responder Compartilhar
Comentar
Visualizações:
Últimas 24 horas: 1
Últimos 7 dias: 10
Últimos 30 dias: 54
Ao todo: 6,642
