Esta versão pode conter edições incorretas. Mude para o último instantâneo verificado.
O que você precisa
Encha uma panela ou frigideira com água suficiente para submergir completamente um iOpener.
Aqueça a água até ferver. Desligue o fogo.
Coloque um iOpener na água quente por 2 a 3 minutos. Certifique-se de que o iOpener esteja totalmente submerso na água.
Use um pegador para retirar o iOpener aquecido da água quente.
Seque bem o iOpener com uma toalha.
Sua bolsa térmica iOpener está pronta para o uso! Se precisar reaquecer o iOpener, aqueça a água até ferver, desligue o fogo e coloque o iOpener na água por 2 a 3 minutos.
Este passo não foi traduzido. Ajude a traduzi-lo
Handling it by the tag, place the heated iOpener across the bottom casing.
Gently place an opening pick in the corner of the gap between the bottom casing and rear case.
Slide the opening pick along the side of the casing, prying it away from the adhesive as you go.
Use your fingers to pull the bottom casing off the rest of the phone.
Starting at the groove near the headphone jack, use a plastic opening tool to lift the top casing.
Use your fingers to pull the top casing off of the rest of the phone.
Remove the following screws holding the rear case to the rest of the phone:
Two 3.15 mm Phillips #00 screws
One 4.15 Torx T5 screw
One 4 mm Torx T5 screw
Place your fingers on either side of the phone and gently push up on the rear case.
Pull the rear case away from the rest of the phone with your hands.
Using the pointed end of a spudger, lift the battery cable and release the connector.
Switching to the flat end of the spudger, work your way underneath the battery and peel it away from the adhesive.
Remove the three 3.15mm Phillips #00 screws from the turquoise case.
Using a plastic opening tool, lift the turquoise case from the end near the headphone jack.
A camera filter is now free to move, so remove it using tweezers.
Use tweezers to lift the yellow polyimide tape that covers the ZIF connectors.
Use the pointed end of a spudger to lift the white tab on the largest ZIF connector opposite the USB connector.
Use the pointed edge of a spudger to work the ZIF cable out of its connector.
Repeat the procedure from steps 19 and 20 to remove the cables from the remaining ZIF connectors.
Using the pointed end of the spudger, pop the antenna cable from its connector on the motherboard.
Remove the 3.15 mm Phillips #00 screw from the motherboard.
Using tweezers, remove the adhesive tape around the headphone jack.
Using a soldering iron set at 400 degrees Celsius (752 degrees Fahrenheit), heat the solder joints lateral to the headphone jack. Use a pair of tweezers to lift the headphone jack from the board.
