Ir para o conteúdo principal
HTC One Max Rear Facing Camera Replacement
O que você precisa
  1. HTC One Max Rear Facing Camera Replacement, Back Case: passo 1, imagem 1 %32
    • Lift back cover while pressing highlighted release switch towards the center of the phone.
    Pergunte ao FixBot
    Comentar
  2. HTC One Max Rear Facing Camera Replacement: passo 2, imagem 1 %32 HTC One Max Rear Facing Camera Replacement: passo 2, imagem 2 %32
    • Remove the four white stickers in each corner that cover the Tri-Wing screws.
    • Remove the white sticker near the buttons that control the volume.
    • Remove the white sticker near the SIM card.
    • Remove the big white sticker with the bar-code in the center of the phone.
    Pergunte ao FixBot
    Comentar
  3. HTC One Max Rear Facing Camera Replacement: passo 3, imagem 1 %32
    • Remove the thirteen Tri-Wing Y00 screws (Upper & Lower screws are 5 mm length, middle screws are 3.8 mm length) from the back case.
    • Disconnect the cable near the volume buttons.
    Pergunte ao FixBot
    Comentar
  4. HTC One Max Rear Facing Camera Replacement: passo 4, imagem 1 %32 HTC One Max Rear Facing Camera Replacement: passo 4, imagem 2 %32
    • Use the small plastic opening tool to pry between the screen and the rear case.
    Pergunte ao FixBot
    Comentar
  5. HTC One Max Rear Facing Camera Replacement, Fingerprint Sensor: passo 5, imagem 1 %32 HTC One Max Rear Facing Camera Replacement, Fingerprint Sensor: passo 5, imagem 2 %32
    Ferramenta utilizada neste passo:
    • Use Tweezers to disconnect the ribbon cable connecting the fingerprint sensor to the motherboard.
    • When replacing the fingerprint sensor, make sure the ribbon cable snaps into the port on the motherboard.
    Pergunte ao FixBot
    Comentar
  6. HTC One Max Rear Facing Camera Replacement, Motherboard: passo 6, imagem 1 %32 HTC One Max Rear Facing Camera Replacement, Motherboard: passo 6, imagem 2 %32
    • Remove the two 2.2 mm Phillips #000 screws holding the battery cable.
    • Use a plastic tool to remove the ribbon cable.
    Pergunte ao FixBot
    Comentar
  7. HTC One Max Rear Facing Camera Replacement: passo 7, imagem 1 %32 HTC One Max Rear Facing Camera Replacement: passo 7, imagem 2 %32
    • Use the plastic opening tool to disconnect the two antenna wires at the top of the phone.
    • Use the plastic opening tool to disconnect a third antenna wire at the bottom of the phone.
    Pergunte ao FixBot
    Comentar
  8. HTC One Max Rear Facing Camera Replacement: passo 8, imagem 1 %32
    • Remove the seven 3 mm Phillips #000 screws from the motherboard.
    Pergunte ao FixBot
    Comentar
  9. HTC One Max Rear Facing Camera Replacement: passo 9, imagem 1 %32 HTC One Max Rear Facing Camera Replacement: passo 9, imagem 2 %32 HTC One Max Rear Facing Camera Replacement: passo 9, imagem 3 %32
    • Use a plastic tool to pry up and disconnect the large ribbon cables on each side of the motherboard.
    • Use caution prying the ribbon cable on the right side because other ribbon cables run under it.
    Pergunte ao FixBot
    Comentar
  10. HTC One Max Rear Facing Camera Replacement: passo 10, imagem 1 %32 HTC One Max Rear Facing Camera Replacement: passo 10, imagem 2 %32 HTC One Max Rear Facing Camera Replacement: passo 10, imagem 3 %32
    • Remove the tape covering three flex cable gate connectors on the bottom left side of the phone.
    • Use small plastic opening tool to pry open the latch on each of these gate connectors to disconnect the three cables.
    Pergunte ao FixBot
    Comentar
  11. HTC One Max Rear Facing Camera Replacement: passo 11, imagem 1 %32 HTC One Max Rear Facing Camera Replacement: passo 11, imagem 2 %32
    • Use a plastic tool to lift and remove the motherboard.
    • Use a heat gun to loosen adhesive at bottom if needed.
    Pergunte ao FixBot
    Comentar
  12. HTC One Max Rear Facing Camera Replacement, IR Blaster: passo 12, imagem 1 %32
    • Remove the three 3 mm Phillips #000 screws from the secondary board at the top.
    Pergunte ao FixBot
    Comentar
  13. HTC One Max Rear Facing Camera Replacement: passo 13, imagem 1 %32
    • Pick up and set aside vibrator, do not disconnect.
    Pergunte ao FixBot
    Comentar
  14. HTC One Max Rear Facing Camera Replacement: passo 14, imagem 1 %32
    • Pull out ribbon cable.
    • Peel back infrared sensor.
    Pergunte ao FixBot
    Comentar
  15. HTC One Max Rear Facing Camera Replacement, Rear Facing Camera: passo 15, imagem 1 %32 HTC One Max Rear Facing Camera Replacement, Rear Facing Camera: passo 15, imagem 2 %32
    • Lift the secondary motherboard with the camera attached.
    Pergunte ao FixBot
    Comentar
  16. HTC One Max Rear Facing Camera Replacement: passo 16, imagem 1 %32 HTC One Max Rear Facing Camera Replacement: passo 16, imagem 2 %32 HTC One Max Rear Facing Camera Replacement: passo 16, imagem 3 %32
    • Use a plastic opening tool to disconnect the camera ribbon cable.
    • Remove rear camera.
    Pergunte ao FixBot
    Comentar
Conclusão
8 outras pessoas executaram este guia.
Andrew Keller
Membro desde: 09/23/14
1.131 Reputação
Autoria de 5 guias
Equipe
USF Tampa, Team 11-3, Blackwell Fall 2014 Membro de USF Tampa, Team 11-3, Blackwell Fall 2014
USFT-BLACKWELL-F14S11G3
4 Membros
Autoria de 7 guias
1Comentário do guia
so..which one do i have to buy?
the Phillips #00 or the #000? the steps say one thing, the required tools section says another.
thanks in advance
alberto rivera - Responder Compartilhar
Comentar
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 12
Últimos 30 dias: 41
Ao todo: 8,506
