Ir para o conteúdo principal
HTC One Max Battery Replacement
O que você precisa
  1. HTC One Max Battery Replacement, Back Case: passo 1, imagem 1 %32
    • Lift back cover while pressing highlighted release switch towards the center of the phone.
    Pergunte ao FixBot
    Comentar
  2. HTC One Max Battery Replacement: passo 2, imagem 1 %32 HTC One Max Battery Replacement: passo 2, imagem 2 %32
    • Remove the four white stickers in each corner that cover the Tri-Wing screws.
    • Remove the white sticker near the buttons that control the volume.
    • Remove the white sticker near the SIM card.
    • Remove the big white sticker with the bar-code in the center of the phone.
    Pergunte ao FixBot
    Comentar
  3. HTC One Max Battery Replacement: passo 3, imagem 1 %32
    • Remove the thirteen Tri-Wing Y00 screws (Upper & Lower screws are 5 mm length, middle screws are 3.8 mm length) from the back case.
    • Disconnect the cable near the volume buttons.
    Pergunte ao FixBot
    Comentar
  4. HTC One Max Battery Replacement: passo 4, imagem 1 %32 HTC One Max Battery Replacement: passo 4, imagem 2 %32
    • Use the small plastic opening tool to pry between the screen and the rear case.
    Pergunte ao FixBot
    Comentar
  5. HTC One Max Battery Replacement, Fingerprint Sensor: passo 5, imagem 1 %32 HTC One Max Battery Replacement, Fingerprint Sensor: passo 5, imagem 2 %32
    Ferramenta utilizada neste passo:
    • Use Tweezers to disconnect the ribbon cable connecting the fingerprint sensor to the motherboard.
    • When replacing the fingerprint sensor, make sure the ribbon cable snaps into the port on the motherboard.
    Pergunte ao FixBot
    Comentar
  6. HTC One Max Battery Replacement, Motherboard: passo 6, imagem 1 %32 HTC One Max Battery Replacement, Motherboard: passo 6, imagem 2 %32
    • Remove the two 2.2 mm Phillips #000 screws holding the battery cable.
    • Use a plastic tool to remove the ribbon cable.
    Pergunte ao FixBot
    Comentar
  7. HTC One Max Battery Replacement: passo 7, imagem 1 %32 HTC One Max Battery Replacement: passo 7, imagem 2 %32
    • Use the plastic opening tool to disconnect the two antenna wires at the top of the phone.
    • Use the plastic opening tool to disconnect a third antenna wire at the bottom of the phone.
    Pergunte ao FixBot
    Comentar
  8. HTC One Max Battery Replacement: passo 8, imagem 1 %32
    • Remove the seven 3 mm Phillips #000 screws from the motherboard.
    Pergunte ao FixBot
    Comentar
  9. HTC One Max Battery Replacement: passo 9, imagem 1 %32 HTC One Max Battery Replacement: passo 9, imagem 2 %32 HTC One Max Battery Replacement: passo 9, imagem 3 %32
    • Use a plastic tool to pry up and disconnect the large ribbon cables on each side of the motherboard.
    • Use caution prying the ribbon cable on the right side because other ribbon cables run under it.
    Pergunte ao FixBot
    Comentar
  10. HTC One Max Battery Replacement: passo 10, imagem 1 %32 HTC One Max Battery Replacement: passo 10, imagem 2 %32 HTC One Max Battery Replacement: passo 10, imagem 3 %32
    • Remove the tape covering three flex cable gate connectors on the bottom left side of the phone.
    • Use small plastic opening tool to pry open the latch on each of these gate connectors to disconnect the three cables.
    Pergunte ao FixBot
    Comentar
  11. HTC One Max Battery Replacement: passo 11, imagem 1 %32 HTC One Max Battery Replacement: passo 11, imagem 2 %32
    • Use a plastic tool to lift and remove the motherboard.
    • Use a heat gun to loosen adhesive at bottom if needed.
    Pergunte ao FixBot
    Comentar
  12. HTC One Max Battery Replacement, IR Blaster: passo 12, imagem 1 %32
    • Remove the three 3 mm Phillips #000 screws from the secondary board at the top.
    Pergunte ao FixBot
    Comentar
  13. HTC One Max Battery Replacement: passo 13, imagem 1 %32
    • Pick up and set aside vibrator, do not disconnect.
    Pergunte ao FixBot
    Comentar
  14. HTC One Max Battery Replacement: passo 14, imagem 1 %32
    • Pull out ribbon cable.
    • Peel back infrared sensor.
    Pergunte ao FixBot
    Comentar
  15. HTC One Max Battery Replacement, Camera Board: passo 15, imagem 1 %32 HTC One Max Battery Replacement, Camera Board: passo 15, imagem 2 %32
    • Pull out the secondary board with the camera attached.
    • Be advised of the adhesive on the back.
    Pergunte ao FixBot
    Comentar
  16. HTC One Max Battery Replacement, Remove Bottom Screws: passo 16, imagem 1 %32
    • Remove two screws from the bottom.
    • Set aside metal retaining plate.
    Pergunte ao FixBot
    Comentar
  17. HTC One Max Battery Replacement, Speaker Assembly: passo 17, imagem 1 %32 HTC One Max Battery Replacement, Speaker Assembly: passo 17, imagem 2 %32
    • Pry back the speaker and microphone assembly from the bottom.
    • Be careful to not poke the speaker.
    Pergunte ao FixBot
    Comentar
  18. HTC One Max Battery Replacement, Remove Battery: passo 18, imagem 1 %32 HTC One Max Battery Replacement, Remove Battery: passo 18, imagem 2 %32 HTC One Max Battery Replacement, Remove Battery: passo 18, imagem 3 %32
    • Pry the battery away from the back of the screen with a plastic tool.
    • We recommend using a heat gun to loosen the adhesive holding the battery in place.
    Pergunte ao FixBot
    Comentar
Conclusão
15 outras pessoas executaram este guia.
Equipe
USF Tampa, Team 11-3, Blackwell Fall 2014 Membro de USF Tampa, Team 11-3, Blackwell Fall 2014
USFT-BLACKWELL-F14S11G3
4 Membros
Autoria de 7 guias
4Comentários do guia
Microphone in the article, battery in the title.
AaronAndrusko - Responder Compartilhar
How to change LCD screen for this model?
Jembalang Tanah - Responder Compartilhar
What the &&^& man i prefer to buy another phone %#*@ it
Russel - Responder Compartilhar
What the &&^& man i prefer to buy a new phone
Comentar
Visualizações:
Últimas 24 horas: 2
Últimos 7 dias: 10
Últimos 30 dias: 47
Ao todo: 16,182
