Introdução
Use this guide to replace the headphone jack/micro USB board on your HTC One M9.
O que você precisa
The microSD card tray is located on the upper right hand side of the phone, above the volume buttons. To open the tray, insert a microSD card eject tool, or a paperclip, into the small hole in the microSD card tray.
Then press the tool or paperclip to eject the microSD card tray.
Insert a SIM card eject tool or a paperclip into the small hole besides the SIM card tray, located on the upper section of the left edge of the phone.
Press to eject the tray.
Using a plastic opening pick or a spudger, gently pry and remove the cover on top of the case.
Remove the two 4 mm T5 Torx screws on the top of the case.
Use a pair of tweezers to lift the vibrator out of its slot.
Use an iOpener or heat gun to loosen the adhesive at the bottom of the motherboard.
Use a plastic opening tool, or a spudger, along the edges of the case to gently pry the motherboard out of the case.
Gently lift the motherboard out of the case, beginning from the top corner (near the camera).
Remove the 3 mm T5 screw that holds the front speaker in place.
Gently remove the speaker from the device.
10 outras pessoas executaram este guia.
Um comentário
Hi,
Make sure to check the headphone board too see if the gps connection in your phone has 1 or 2 cable ports.(Blue jumper wires) Mine has 1 so I got a sim card error. Waiting for usb board with one cable to fix
