Ir para o conteúdo principal
HTC One M8 Rear Case Replacement
O que você precisa
  1. HTC One M8 Rear Case Replacement, SIM Card: passo 1, imagem 1 %32 HTC One M8 Rear Case Replacement, SIM Card: passo 1, imagem 2 %32
    • Insert a SIM card eject tool or a paperclip into the small hole in the SIM card tray, located on the upper left hand side of the phone.
    • Press to eject the tray.
    • This may require a significant amount of force.
  2. HTC One M8 Rear Case Replacement: passo 2, imagem 1 %32
    • Remove the SIM card tray assembly from the HTC One M8.
    • When reinserting the SIM card, ensure that it is in the proper orientation relative to the tray.
  3. HTC One M8 Rear Case Replacement, MicroSD Card: passo 3, imagem 1 %32 HTC One M8 Rear Case Replacement, MicroSD Card: passo 3, imagem 2 %32
    • Insert a SIM card eject tool or a paperclip into the small hole in the microSD card tray, located on the upper right hand side of the phone.
  4. HTC One M8 Rear Case Replacement: passo 4, imagem 1 %32
    • Remove the microSD card tray assembly from the HTC One M8.
    • When reinserting the microSD card, ensure that it is in the proper orientation relative to the tray.
  5. HTC One M8 Rear Case Replacement, Rear Case: passo 5, imagem 1 %32 HTC One M8 Rear Case Replacement, Rear Case: passo 5, imagem 2 %32
    • Use an iOpener or heat gun to loosen the adhesive on the upper and lower speaker grilles.
    • Refer to the iOpener guide for info on how to use the iOpener.
  6. HTC One M8 Rear Case Replacement: passo 6, imagem 1 %32 HTC One M8 Rear Case Replacement: passo 6, imagem 2 %32 HTC One M8 Rear Case Replacement: passo 6, imagem 3 %32
    • Use a plastic opening tool to gently peel up the lower speaker grille.
    • The adhesive is messy, and can be removed using Goo-gone.
  7. HTC One M8 Rear Case Replacement: passo 7, imagem 1 %32 HTC One M8 Rear Case Replacement: passo 7, imagem 2 %32
    • Use a plastic opening tool to gently peel up the upper speaker grille.
  8. HTC One M8 Rear Case Replacement: passo 8, imagem 1 %32
    • Remove the two silver 3 mm Phillips #00 screws from the top.
    • Remove the four black 4 mm T5 Torx screws from the bottom.
  9. HTC One M8 Rear Case Replacement: passo 9, imagem 1 %32 HTC One M8 Rear Case Replacement: passo 9, imagem 2 %32 HTC One M8 Rear Case Replacement: passo 9, imagem 3 %32
    • Work your way around the perimeter of the phone with a spudger and plastic opening picks to free the clips that secure the rear case to the display assembly.
    • A metal spudger is pictured, but it is best to use a nylon spudger to prevent marring the device.
    • Be careful not to lose the power button: it sits loosely in the top of the lower chassis.
    • Significant force may be required to pry the casing apart.
Conclusão
12 outras pessoas executaram este guia.
Michael Gonzalez
Membro desde: 04/14/15
4.430 Reputação
Autoria de 5 guias
Equipe
Cal Poly, Team 5-9, Maness Spring 2015 Membro de Cal Poly, Team 5-9, Maness Spring 2015
CPSU-MANESS-S15S5G9
Membros da 4
Autoria de 18 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 6
Últimos 30 dias: 22
Duração total: 6,942
