Ir para o conteúdo principal
HTC Maple 100 Trackball Replacement
O que você precisa
  1. HTC Maple 100 Trackball Replacement, Battery: passo 1, imagem 1 %32
    • First remove the back cover of your phone to expose the battery.
    Pergunte ao FixBot
    Comentar
  2. HTC Maple 100 Trackball Replacement: passo 2, imagem 1 %32
    • Turn the phone over.
    • Push forward on the battery with your thumb.
    Pergunte ao FixBot
    Comentar
  3. HTC Maple 100 Trackball Replacement: passo 3, imagem 1 %32 HTC Maple 100 Trackball Replacement: passo 3, imagem 2 %32
    • Take the battery out by lifting it upwards.
    • When reassembling, make sure that the battery contacts match up.
    Pergunte ao FixBot
    Comentar
  4. HTC Maple 100 Trackball Replacement, Back Panel: passo 4, imagem 1 %32 HTC Maple 100 Trackball Replacement, Back Panel: passo 4, imagem 2 %32
    • Remove the four 4.9mm T6 Torx screws that secure the back panel to the rest of the phone.
    Pergunte ao FixBot
    Comentar
  5. HTC Maple 100 Trackball Replacement: passo 5, imagem 1 %32
    • Remove the two 4.3mm Phillips #00 screws that secure the back panel to the rest of the phone.
    Pergunte ao FixBot
    Comentar
  6. HTC Maple 100 Trackball Replacement: passo 6, imagem 1 %32 HTC Maple 100 Trackball Replacement: passo 6, imagem 2 %32 HTC Maple 100 Trackball Replacement: passo 6, imagem 3 %32
    • Insert the plastic opening tool along the seams at different points to it pry the clips off.
    • This may require a bit of force. The USB port cover may fall off in this step.
    Pergunte ao FixBot
    Comentar
  7. HTC Maple 100 Trackball Replacement, Motherboard: passo 7, imagem 1 %32 HTC Maple 100 Trackball Replacement, Motherboard: passo 7, imagem 2 %32
    • Remove the one 3.3mm Phillips #00 screw.
    Pergunte ao FixBot
    Comentar
  8. HTC Maple 100 Trackball Replacement: passo 8, imagem 1 %32 HTC Maple 100 Trackball Replacement: passo 8, imagem 2 %32
    • Use your finger or the plastic opening tool to unclip the board.
    • Be aware of the ribbon cable connected to the motherboard inside the phone.
    Pergunte ao FixBot
    Comentar
  9. HTC Maple 100 Trackball Replacement: passo 9, imagem 1 %32 HTC Maple 100 Trackball Replacement: passo 9, imagem 2 %32
    • Peel off the yellow piece of tape from the phone.
    Pergunte ao FixBot
    Comentar
  10. HTC Maple 100 Trackball Replacement: passo 10, imagem 1 %32 HTC Maple 100 Trackball Replacement: passo 10, imagem 2 %32 HTC Maple 100 Trackball Replacement: passo 10, imagem 3 %32
    • Flip up the retaining flap with your fingernail or a plastic opening tool.
    • Pull on the ribbon cable gently with your fingers.
    Pergunte ao FixBot
    Comentar
  11. HTC Maple 100 Trackball Replacement: passo 11, imagem 1 %32 HTC Maple 100 Trackball Replacement: passo 11, imagem 2 %32
    • Split apart the motherboard and front panel.
    • Remove the other yellow piece of tape off of the end of the ribbon cable.
    Pergunte ao FixBot
    Comentar
  12. HTC Maple 100 Trackball Replacement: passo 12, imagem 1 %32 HTC Maple 100 Trackball Replacement: passo 12, imagem 2 %32
    • Gently pull on the ribbon cable to separate the motherboard.
    Pergunte ao FixBot
    Comentar
  13. HTC Maple 100 Trackball Replacement, Trackball: passo 13, imagem 1 %32 HTC Maple 100 Trackball Replacement, Trackball: passo 13, imagem 2 %32 HTC Maple 100 Trackball Replacement, Trackball: passo 13, imagem 3 %32
    • Using your fingers, gently pull the trackball out.
    Pergunte ao FixBot
    Comentar
Conclusão
Nick
Membro desde: 10/28/11
6 Reputação
Autoria de 3 guias
Equipe
Cal Poly, Team 20-29, Maness Fall 2011 Membro de Cal Poly, Team 20-29, Maness Fall 2011
CPSU-MANESS-F11S20G29
4 Membros
Autoria de 18 guias
0Comentários do guia
Comentar
Visualizações:
Últimas 24 horas: 1
Últimos 7 dias: 8
Últimos 30 dias: 29
Ao todo: 1,575
