Ir para o conteúdo principal
HTC Magic SIM Card Replacement
  1. HTC Magic SIM Card Replacement, SIM Card: passo 1, imagem 1 %32 HTC Magic SIM Card Replacement, SIM Card: passo 1, imagem 2 %32
    • Push down firmly on the back cover of the phone and pull it back.
    • It will only slide back about half an inch, after that you can lift it up.
    Pergunte ao FixBot
    Comentar
  2. HTC Magic SIM Card Replacement: passo 2, imagem 1 %32
    • Take out the battery using the two tabs at the upper right and upper left corner of the battery.
    Pergunte ao FixBot
    Comentar
  3. HTC Magic SIM Card Replacement: passo 3, imagem 1 %32
    • Take out the simcard by putting your finger on the revealing bit of the card and pulling it out towards you.
    • If it doesn't work immediately, try using the small open space near the bottom of the simcard to partially push it forward.
    Pergunte ao FixBot
    Comentar
Conclusão
3 outras pessoas executaram este guia.
LucasJV
Membro desde: 05/18/10
741 Reputação
Autoria de 3 guias
0Comentários do guia
Comentar
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 9
Últimos 30 dias: 34
Ao todo: 3,855
