Ir para o conteúdo principal
HTC Incredible 2 SIM Card Replacement
  1. HTC Incredible 2 SIM Card Replacement, Disassembling HTC Incredible 2 Back Panel: passo 1, imagem 1 %32 HTC Incredible 2 SIM Card Replacement, Disassembling HTC Incredible 2 Back Panel: passo 1, imagem 2 %32
    • Press your thumbnail into the slot between the rear panel and the front casing located on the bottom of the phone. Use a penny or dime if you have trouble using your thumbnail.
    • With a moderate amount of force, pry the rear panel up and away from the phone. You may need to slide your thumbnail up the crack to separate the rear panel from the front casing.
    • This can take a little bit of effort. Don't be discouraged if you can't get it right away.
    Pergunte ao FixBot
    Comentar
  2. HTC Incredible 2 SIM Card Replacement: passo 2, imagem 1 %32
    • Remove the rear panel from the phone.
    Pergunte ao FixBot
    Comentar
  3. HTC Incredible 2 SIM Card Replacement, Battery: passo 3, imagem 1 %32
    • Press your fingernail into the slot between the battery and the rear inner frame, located between the battery and LED lights.
    • Use a penny or dime if you can't use your fingernail.
    Pergunte ao FixBot
    Comentar
  4. HTC Incredible 2 SIM Card Replacement: passo 4, imagem 1 %32 HTC Incredible 2 SIM Card Replacement: passo 4, imagem 2 %32
    • Gently lever the battery up and away from the lights.
    • Lift the top of the battery up and remove the battery from the rear inner frame.
    Pergunte ao FixBot
    Comentar
  5. HTC Incredible 2 SIM Card Replacement, SIM Card: passo 5, imagem 1 %32 HTC Incredible 2 SIM Card Replacement, SIM Card: passo 5, imagem 2 %32
    • Apply pressure with your fingertip to the pressure clip beneath the SIM card.
    • While keeping pressure on the clip, use another finger to gently slide the SIM card down over the clip.
    Pergunte ao FixBot
    Comentar
  6. HTC Incredible 2 SIM Card Replacement: passo 6, imagem 1 %32 HTC Incredible 2 SIM Card Replacement: passo 6, imagem 2 %32
    • Keep sliding SIM card until completely free from holding apparatus. Now remove the SIM card.
    Pergunte ao FixBot
    Comentar
Conclusão
William Slope
Membro desde: 04/22/14
130 Reputação
Autoria de 1 guia
Equipe
Cal Poly, Team 11-53, Amido Spring 2014 Membro de Cal Poly, Team 11-53, Amido Spring 2014
CPSU-AMIDO-S14S11G53
5 Membros
Autoria de 14 guias
0Comentários do guia
Comentar
Visualizações:
Últimas 24 horas: 3
Últimos 7 dias: 14
Últimos 30 dias: 39
Ao todo: 1,567
