Ir para o conteúdo principal
HTC Hero Trackball Replacement
O que você precisa
  1. HTC Hero Trackball Replacement, Back Case: passo 1, imagem 1 %32
    • Remove the back of the phone by pushing firmly with your thumbs up towards the camera.
    • Remove both the battery and the SD card (Press SD card in to release)
    • Locate and remove the four Torx screws highlighted in the photo, with the phone laying face down on your work space.
    Pergunte ao FixBot
    Comentar
  2. HTC Hero Trackball Replacement: passo 2, imagem 1 %32
    • Carefully pry the inside back cover from the device using an appropriate size plastic opening tool or small flathead screwdriver.
    • Insert the flat end between the back and front enclosure, working your way around the rim.
    Pergunte ao FixBot
    Comentar
  3. HTC Hero Trackball Replacement: passo 3, imagem 1 %32
    • Gently depress and release the small plastic tabs around the rim in the front enclosure, highlighted here.
    • It is best to start with the tab found on the top center of the phone, as it is easiest to locate.
    Pergunte ao FixBot
    Comentar
  4. HTC Hero Trackball Replacement: passo 4, imagem 1 %32 HTC Hero Trackball Replacement: passo 4, imagem 2 %32
    • Carefully separate the front and back enclosures once all of the clips have been disengaged.
    • Be sure to not separate too quickly or you risk breaking an attached tab.
    Pergunte ao FixBot
    Comentar
  5. HTC Hero Trackball Replacement, Trackball: passo 5, imagem 1 %32 HTC Hero Trackball Replacement, Trackball: passo 5, imagem 2 %32
    • Remove the two screws near the bottom of the motherboard with a Phillips head screwdriver.
    Pergunte ao FixBot
    Comentar
  6. HTC Hero Trackball Replacement: passo 6, imagem 1 %32 HTC Hero Trackball Replacement: passo 6, imagem 2 %32
    • Gently pull off the ribbons holding the sides of the motherboard to the front enclosure.
    Pergunte ao FixBot
    Comentar
  7. HTC Hero Trackball Replacement: passo 7, imagem 1 %32 HTC Hero Trackball Replacement: passo 7, imagem 2 %32
    • Remove the motherboard from within the front enclosure.
    • Be careful when pulling the ribbons off the motherboard as they may rip or break.
    Pergunte ao FixBot
    Comentar
  8. HTC Hero Trackball Replacement: passo 8, imagem 1 %32 HTC Hero Trackball Replacement: passo 8, imagem 2 %32
    • Tilt the inside of the front enclosure towards your cupped palm to remove the trackball and it's enclosure will fall out.
    Pergunte ao FixBot
    Comentar
  9. HTC Hero Trackball Replacement: passo 9, imagem 1 %32 HTC Hero Trackball Replacement: passo 9, imagem 2 %32 HTC Hero Trackball Replacement: passo 9, imagem 3 %32
    • Position the phone off of the edge of the table and insert the replacement part by inserting the bevel then the trackball into the hole.
    • Make sure the two plastic pins on the trackball bevel are oriented horizontally.
    Pergunte ao FixBot
    Comentar
Conclusão
Uma outra pessoa concluiu este guia.
Max Brown
Membro desde: 01/23/12
139 Reputação
Autoria de 4 guias
Equipe
Cal Poly, Team 3-26, Amido Winter 2012 Membro de Cal Poly, Team 3-26, Amido Winter 2012
CPSU-AMIDO-W12S3G26
5 Membros
Autoria de 18 guias
0Comentários do guia
Comentar
Visualizações:
Últimas 24 horas: 1
Últimos 7 dias: 7
Últimos 30 dias: 36
Ao todo: 1,907
