Ir para o conteúdo principal
HTC Hero Touch Screen Digitizer Replacement
O que você precisa
  1. HTC Hero Touch Screen Digitizer Replacement, Back Case: passo 1, imagem 1 %32
    • Remove the back of the phone by pushing firmly with your thumbs up towards the camera.
    • Remove both the battery and the SD card (Press SD card in to release)
    • Locate and remove the four Torx screws highlighted in the photo, with the phone laying face down on your work space.
    Pergunte ao FixBot
    Comentar
  2. HTC Hero Touch Screen Digitizer Replacement: passo 2, imagem 1 %32
    • Carefully pry the inside back cover from the device using an appropriate size plastic opening tool or small flathead screwdriver.
    • Insert the flat end between the back and front enclosure, working your way around the rim.
    Pergunte ao FixBot
    Comentar
  3. HTC Hero Touch Screen Digitizer Replacement: passo 3, imagem 1 %32
    • Gently depress and release the small plastic tabs around the rim in the front enclosure, highlighted here.
    • It is best to start with the tab found on the top center of the phone, as it is easiest to locate.
    Pergunte ao FixBot
    Comentar
  4. HTC Hero Touch Screen Digitizer Replacement: passo 4, imagem 1 %32 HTC Hero Touch Screen Digitizer Replacement: passo 4, imagem 2 %32
    • Carefully separate the front and back enclosures once all of the clips have been disengaged.
    • Be sure to not separate too quickly or you risk breaking an attached tab.
    Pergunte ao FixBot
    Comentar
  5. HTC Hero Touch Screen Digitizer Replacement, Touch Screen: passo 5, imagem 1 %32 HTC Hero Touch Screen Digitizer Replacement, Touch Screen: passo 5, imagem 2 %32
    • Gently release the two ribbon cables using a plastic opening tool by prying up the pop connectors used to attach the ribbon cables to the motherboard.
    Pergunte ao FixBot
    Comentar
  6. HTC Hero Touch Screen Digitizer Replacement: passo 6, imagem 1 %32 HTC Hero Touch Screen Digitizer Replacement: passo 6, imagem 2 %32
    • Remove the two screws located at the bottom left and right of the motherboard using a small Phillips screwdriver.
    Pergunte ao FixBot
    Comentar
  7. HTC Hero Touch Screen Digitizer Replacement: passo 7, imagem 1 %32 HTC Hero Touch Screen Digitizer Replacement: passo 7, imagem 2 %32
    • Gently lift the motherboard out of the front enclosure once the screws are removed.
    Pergunte ao FixBot
    Comentar
  8. HTC Hero Touch Screen Digitizer Replacement: passo 8, imagem 1 %32 HTC Hero Touch Screen Digitizer Replacement: passo 8, imagem 2 %32 HTC Hero Touch Screen Digitizer Replacement: passo 8, imagem 3 %32
    • Remove the trackball and its enclosure by turning the phone over into your cupped hand and allowing the trackball and enclosure to fall out.
    Pergunte ao FixBot
    Comentar
  9. HTC Hero Touch Screen Digitizer Replacement: passo 9, imagem 1 %32 HTC Hero Touch Screen Digitizer Replacement: passo 9, imagem 2 %32 HTC Hero Touch Screen Digitizer Replacement: passo 9, imagem 3 %32
    • Gently pry out the LCD screen from the top left side of the enclosure using a plastic tool, as illustrated.
    Pergunte ao FixBot
    Comentar
  10. HTC Hero Touch Screen Digitizer Replacement: passo 10, imagem 1 %32 HTC Hero Touch Screen Digitizer Replacement: passo 10, imagem 2 %32
    • Using a plastic opening tool, gently pry the glass from the frame by inserting the flat end between the glass and the frame from the inside of the phone.
    • Follow the edges of the glass to ensure that all the adhesive has been released.
    Pergunte ao FixBot
    Comentar
  11. HTC Hero Touch Screen Digitizer Replacement: passo 11, imagem 1 %32
    • Using a heat lamp or gun, warm the glass to loosen the adhesive binding it to the frame.
    • Once the adhesive has been released, you should be able to remove the glass by pushing on it from the inside of the phone.
    • Be careful to remove the glass slowly. The ribbon cable that connects to the glass is routed through the plastic frame at the bottom.
    Pergunte ao FixBot
    Comentar
  12. HTC Hero Touch Screen Digitizer Replacement: passo 12, imagem 1 %32 HTC Hero Touch Screen Digitizer Replacement: passo 12, imagem 2 %32 HTC Hero Touch Screen Digitizer Replacement: passo 12, imagem 3 %32
    • Carefully feed the ribbon cable through the slot in the plastic frame.
    Pergunte ao FixBot
    Comentar
  13. HTC Hero Touch Screen Digitizer Replacement: passo 13, imagem 1 %32
    • Remove any excess adhesive from the plastic frame.
    Pergunte ao FixBot
    Comentar
Conclusão
Max Brown
Membro desde: 01/23/12
139 Reputação
Autoria de 4 guias
Equipe
Cal Poly, Team 3-26, Amido Winter 2012 Membro de Cal Poly, Team 3-26, Amido Winter 2012
CPSU-AMIDO-W12S3G26
5 Membros
Autoria de 18 guias
0Comentários do guia
Comentar
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 4
Últimos 30 dias: 32
Ao todo: 3,824
