Ir para o conteúdo principal
HTC HD2 Midframe Replacement
O que você precisa
    1. HTC HD2 Midframe Replacement, Battery: passo 1, imagem 1 %32
      • Carefully pull the rear cover from the back of the phone.
      • Place a finger beneath the small lip on the left side of the battery.
      Pergunte ao FixBot
      Comentar
    2. HTC HD2 Midframe Replacement: passo 2, imagem 1 %32 HTC HD2 Midframe Replacement: passo 2, imagem 2 %32
      • Lay the phone down on it's screen.
      • Lift up on the lip and pull the battery from the phone.
      Pergunte ao FixBot
      Comentar
    1. HTC HD2 Midframe Replacement, Midframe: passo 3, imagem 1 %32 HTC HD2 Midframe Replacement, Midframe: passo 3, imagem 2 %32
      • Remove the four black 3.5mm T5 screws from the back of the phone.
      Pergunte ao FixBot
      Comentar
    2. HTC HD2 Midframe Replacement: passo 4, imagem 1 %32 HTC HD2 Midframe Replacement: passo 4, imagem 2 %32
      • Insert the flat end of a spudger between the midframe and the display.
      • Slide the spudger along the seam between the frame and the display.
      • Using the spudger for leverage, carefully pry the midframe away from the display assembly.
      • This process will take some effort. Continue to pry slowly and carefully until the frame begins to detach.
      • As it releases, pull the midframe away from the phone.
      • The volume control tab may fall off during removal. It can be easily reattached.
      Pergunte ao FixBot
      Comentar
Conclusão
4 outras pessoas executaram este guia.
Equipe
Cal Poly, Team 24-55, Amido Spring 2011 Membro de Cal Poly, Team 24-55, Amido Spring 2011
CPSU-AMIDO-S11S24G55
5 Membros
Autoria de 96 guias
0Comentários do guia
Comentar
Visualizações:
Últimas 24 horas: 2
Últimos 7 dias: 8
Últimos 30 dias: 22
Ao todo: 9,301
