Ir para o conteúdo principal
HTC HD2 Camera Replacement
O que você precisa
    1. HTC HD2 Camera Replacement, Battery: passo 1, imagem 1 %32
      • Carefully pull the rear cover from the back of the phone.
      • Place a finger beneath the small lip on the left side of the battery.
      Pergunte ao FixBot
      Comentar
    2. HTC HD2 Camera Replacement: passo 2, imagem 1 %32 HTC HD2 Camera Replacement: passo 2, imagem 2 %32
      • Lay the phone down on it's screen.
      • Lift up on the lip and pull the battery from the phone.
      Pergunte ao FixBot
      Comentar
    1. HTC HD2 Camera Replacement, Midframe: passo 3, imagem 1 %32 HTC HD2 Camera Replacement, Midframe: passo 3, imagem 2 %32
      • Remove the four black 3.5mm T5 screws from the back of the phone.
      Pergunte ao FixBot
      Comentar
    2. HTC HD2 Camera Replacement: passo 4, imagem 1 %32 HTC HD2 Camera Replacement: passo 4, imagem 2 %32
      • Insert the flat end of a spudger between the midframe and the display.
      • Slide the spudger along the seam between the frame and the display.
      • Using the spudger for leverage, carefully pry the midframe away from the display assembly.
      • This process will take some effort. Continue to pry slowly and carefully until the frame begins to detach.
      • As it releases, pull the midframe away from the phone.
      • The volume control tab may fall off during removal. It can be easily reattached.
      Pergunte ao FixBot
      Comentar
    1. HTC HD2 Camera Replacement, Camera: passo 5, imagem 1 %32 HTC HD2 Camera Replacement, Camera: passo 5, imagem 2 %32 HTC HD2 Camera Replacement, Camera: passo 5, imagem 3 %32
      • Disconnect the flash cable from its socket in the bottom of the motherboard.
      • Carefully pull the cable from its groove in the frame, working your way back to the camera.
      Pergunte ao FixBot
      Comentar
    2. HTC HD2 Camera Replacement: passo 6, imagem 1 %32 HTC HD2 Camera Replacement: passo 6, imagem 2 %32 HTC HD2 Camera Replacement: passo 6, imagem 3 %32
      • Pull the camera flash and cover off of the board.
      • You may need to peel back the sticker that sits behind the battery.
      • Work carefully. Excessive force can damage the camera or motherboard.
      Pergunte ao FixBot
      Comentar
    3. HTC HD2 Camera Replacement: passo 7, imagem 1 %32
      Ferramenta utilizada neste passo:
      • Around the camera is a thin shielding. Remove it with tweezers.
      • Using tweezers, remove the primary camera.
      Pergunte ao FixBot
      Comentar
Conclusão
Sam Luedloff
Membro desde: 04/12/11
727 Reputação
Autoria de 3 guias
Equipe
Cal Poly, Team 24-55, Amido Spring 2011 Membro de Cal Poly, Team 24-55, Amido Spring 2011
CPSU-AMIDO-S11S24G55
5 Membros
Autoria de 56 guias
0Comentários do guia
Comentar
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 6
Últimos 30 dias: 46
Ao todo: 8,429
