Ir para o conteúdo principal
HTC Freestyle Rear Facing Camera Replacement
O que você precisa
  1. HTC Freestyle Rear Facing Camera Replacement, Remove back cover: passo 1, imagem 1 %32 HTC Freestyle Rear Facing Camera Replacement, Remove back cover: passo 1, imagem 2 %32
    • Apply pressure to the dark plastic casing and slide the casing downward, off of the phone.
    Pergunte ao FixBot
    Comentar
  2. HTC Freestyle Rear Facing Camera Replacement, Open plastic flap.: passo 2, imagem 1 %32 HTC Freestyle Rear Facing Camera Replacement, Open plastic flap.: passo 2, imagem 2 %32
    • Fold the plastic flap open.
    Pergunte ao FixBot
    Comentar
  3. HTC Freestyle Rear Facing Camera Replacement, Reveal the battery: passo 3, imagem 1 %32 HTC Freestyle Rear Facing Camera Replacement, Reveal the battery: passo 3, imagem 2 %32
    • Pull on the red tab to slide the battery out.
    • Take out the battery.
    • Replace with new battery.
    Pergunte ao FixBot
    Comentar
  4. HTC Freestyle Rear Facing Camera Replacement, Remove screws from plastic flap: passo 4, imagem 1 %32
    • Use a T5 Torx screwdriver to remove the five screws anchoring the plastic flap to the phone.
    • One of the five screws may be hidden beneath a "Void" sticker to the right of the serial label.
    Pergunte ao FixBot
    Comentar
  5. HTC Freestyle Rear Facing Camera Replacement, Remove plastic flap from phone: passo 5, imagem 1 %32
    • Once the screws are removed from the plastic flap, the piece should easily come out.
    Pergunte ao FixBot
    Comentar
  6. HTC Freestyle Rear Facing Camera Replacement, Remove circuiting panel: passo 6, imagem 1 %32 HTC Freestyle Rear Facing Camera Replacement, Remove circuiting panel: passo 6, imagem 2 %32
    • After the screws are removed, fold circuit panel upwards, exposing the phone's primary buttons.
    • In order to remove the circuit board you must disconnect the labeled component.
    Pergunte ao FixBot
    Comentar
  7. HTC Freestyle Rear Facing Camera Replacement, Remove primary buttons: passo 7, imagem 1 %32
    Ferramenta utilizada neste passo:
    • Once the back side of the buttons are exposed, they will fall out either by punching them out from the front side, or by using tweezers to pull them out of the back.
    Pergunte ao FixBot
    Comentar
  8. HTC Freestyle Rear Facing Camera Replacement, Separate phone housing from electrical components: passo 8, imagem 1 %32 HTC Freestyle Rear Facing Camera Replacement, Separate phone housing from electrical components: passo 8, imagem 2 %32
    • Rotate your HTC Freestyle so that the main screen is facing upward and toward you.
    • Use a plastic opening tool to pry the screen and electronic internals apart from the main phone housing.
    Pergunte ao FixBot
    Comentar
  9. HTC Freestyle Rear Facing Camera Replacement, Remove screws from internal component: passo 9, imagem 1 %32 HTC Freestyle Rear Facing Camera Replacement, Remove screws from internal component: passo 9, imagem 2 %32
    • Orient the component so that the battery compartment and camera are facing upwards.
    • Use the #00 Phillips screwdriver to remove the exterior screws that are holding the piece together.
    • There should be screws on both lateral sides of the phone as well as one screw in the top corner to the right of the camera
    Pergunte ao FixBot
    Comentar
  10. HTC Freestyle Rear Facing Camera Replacement, Separate the internal component into two halves: passo 10, imagem 1 %32 HTC Freestyle Rear Facing Camera Replacement, Separate the internal component into two halves: passo 10, imagem 2 %32
    • Once the screws are removed, the motherboard can be separated from the other components after prying open the gold-colored clamps hidden underneath the battery compartment.
    • Rotate the phone 180 degrees and pry the second clamp that is located on the other side of the component.
    • The motherboard will then easily be removed from the rest.
    Pergunte ao FixBot
    Comentar
  11. HTC Freestyle Rear Facing Camera Replacement, Pry the screen from the front of the phone: passo 11, imagem 1 %32 HTC Freestyle Rear Facing Camera Replacement, Pry the screen from the front of the phone: passo 11, imagem 2 %32
    • Once the screen and motherboard are separated, use a plastic opening tool to pry along the edges of the touchscreen. **Note, the use of a heat gun/heating element will help loosen the adhesive from behind the screen to make prying less physically straining.
    • The screen should now be fully removed.
    Pergunte ao FixBot
    Comentar
  12. HTC Freestyle Rear Facing Camera Replacement, Locate and remove camera: passo 12, imagem 1 %32 HTC Freestyle Rear Facing Camera Replacement, Locate and remove camera: passo 12, imagem 2 %32
    • The camera should still be attached to the battery compartment and can be removed by pushing directly on the lens with either a finger or plastic opening tool.
    Pergunte ao FixBot
    Comentar
Conclusão
Uma outra pessoa concluiu este guia.
Erik Chmura
Membro desde: 10/14/14
134 Reputação
Autoria de 1 guia
Equipe
USF Tampa, Team 8-3, Leahy Fall 2014 Membro de USF Tampa, Team 8-3, Leahy Fall 2014
USFT-LEAHY-F14S8G3
4 Membros
Autoria de 10 guias
0Comentários do guia
Comentar
Visualizações:
Últimas 24 horas: 2
Últimos 7 dias: 6
Últimos 30 dias: 23
Ao todo: 642
