Ir para o conteúdo principal
HTC Fortress Camera Replacement
O que você precisa
  1. HTC Fortress Camera Replacement, Battery: passo 1, imagem 1 %32 HTC Fortress Camera Replacement, Battery: passo 1, imagem 2 %32
    • Remove the back cover of the device by sliding it upward.
    • You may need to remove the phone stylus first.
    Pergunte ao FixBot
    Comentar
  2. HTC Fortress Camera Replacement: passo 2, imagem 1 %32 HTC Fortress Camera Replacement: passo 2, imagem 2 %32
    • Remove the battery by pulling it away from the back of the phone.
    Pergunte ao FixBot
    Comentar
  3. HTC Fortress Camera Replacement, Camera: passo 3, imagem 1 %32 HTC Fortress Camera Replacement, Camera: passo 3, imagem 2 %32
    • Remove the top 2 screws on the back of the phone with the T4 Screwdriver.
    Pergunte ao FixBot
    Comentar
  4. HTC Fortress Camera Replacement: passo 4, imagem 1 %32 HTC Fortress Camera Replacement: passo 4, imagem 2 %32 HTC Fortress Camera Replacement: passo 4, imagem 3 %32
    • Remove the camera panel by hand (black cover above the battery slot).
    • Be careful; there is a cable attached underneath the case. It does detach, just pull on it carefully.
    • During reassembly, put the cable back in by holding the black piece slightly above its slot and using the spudger to gently press the end of the cable back into its fitting. Then, insert the black piece so it is flush with the black panel again.
    Pergunte ao FixBot
    Comentar
  5. HTC Fortress Camera Replacement: passo 5, imagem 1 %32 HTC Fortress Camera Replacement: passo 5, imagem 2 %32 HTC Fortress Camera Replacement: passo 5, imagem 3 %32
    • Work the metal camera casing off by slowly prying up the sides using the spudger.
    Pergunte ao FixBot
    Comentar
  6. HTC Fortress Camera Replacement: passo 6, imagem 1 %32 HTC Fortress Camera Replacement: passo 6, imagem 2 %32
    Ferramenta utilizada neste passo:
    • Use the tweezers to pull the camera straight out of the phone.
    Pergunte ao FixBot
    Comentar
Conclusão
Uma outra pessoa concluiu este guia.
Lucas David
Membro desde: 04/19/13
540 Reputação
Autoria de 9 guias
Equipe
Cal Poly, Team 4-13, Maness Spring 2013 Membro de Cal Poly, Team 4-13, Maness Spring 2013
CPSU-MANESS-S13S4G13
4 Membros
Autoria de 22 guias
0Comentários do guia
Comentar
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 2
Últimos 30 dias: 30
Ao todo: 707
