Ir para o conteúdo principal
HTC Flyer MicroUSB Port Replacement
O que você precisa
    1. HTC Flyer MicroUSB Port Replacement, Back Cover: passo 1, imagem 1 %32 HTC Flyer MicroUSB Port Replacement, Back Cover: passo 1, imagem 2 %32 HTC Flyer MicroUSB Port Replacement, Back Cover: passo 1, imagem 3 %32
      • Apply pressure along the bottom of the white panel containing the camera and push upwards.
      • It may take some effort, but it will smoothly slide off.
      Pergunte ao FixBot
      Comentar
    2. HTC Flyer MicroUSB Port Replacement: passo 2, imagem 1 %32 HTC Flyer MicroUSB Port Replacement: passo 2, imagem 2 %32 HTC Flyer MicroUSB Port Replacement: passo 2, imagem 3 %32
      • Unscrew the four of 3.5mm Torx T5 screws that run along the sides of the exposed innards.
      • All screws in the device will use the Torx T5 screwdriver, so keep it handy.
      Pergunte ao FixBot
      Comentar
    3. HTC Flyer MicroUSB Port Replacement: passo 3, imagem 1 %32 HTC Flyer MicroUSB Port Replacement: passo 3, imagem 2 %32 HTC Flyer MicroUSB Port Replacement: passo 3, imagem 3 %32
      • Remove the black protective piece of plastic by sliding it upwards.
      • Remove the two 3.5mm Torx #5 screws holding the protective plastic down on along the sides.
      • A center 3.5mm Torx screw will be covered by "VOID" sticker.
      • Either remove the sticker or jam the screwdriver into the screw, and remove the screw.
      • Remove the protective panel by sliding it upwards.
      Pergunte ao FixBot
      Comentar
    4. HTC Flyer MicroUSB Port Replacement: passo 4, imagem 1 %32 HTC Flyer MicroUSB Port Replacement: passo 4, imagem 2 %32
      • Before removing the back cover, apply some scotch tape to the volume buttons to prevent them from falling out of the back panel.
      • Use a plastic opening tool to lever up the top half of the cover.
      • Lift the back panel up and remove it from the device.
      Pergunte ao FixBot
      Comentar
    1. HTC Flyer MicroUSB Port Replacement, Battery: passo 5, imagem 1 %32 HTC Flyer MicroUSB Port Replacement, Battery: passo 5, imagem 2 %32
      • Gently unfold the black tape along the top that covers the cable attachment points.
      • Leave the tape partially attached so that it can be easily re-attached.
      Pergunte ao FixBot
      Comentar
    2. HTC Flyer MicroUSB Port Replacement: passo 6, imagem 1 %32 HTC Flyer MicroUSB Port Replacement: passo 6, imagem 2 %32 HTC Flyer MicroUSB Port Replacement: passo 6, imagem 3 %32
      • Use the tip of a spudger as a lever to disconnect the four cable connectors.
      • Gently pull out these cables after releasing the back piece.
      Pergunte ao FixBot
      Comentar
    3. HTC Flyer MicroUSB Port Replacement: passo 7, imagem 1 %32
      • Remove the single 2.5mm Torx T5 screw holding the battery down along the top side.
      Pergunte ao FixBot
      Comentar
    4. HTC Flyer MicroUSB Port Replacement: passo 8, imagem 1 %32 HTC Flyer MicroUSB Port Replacement: passo 8, imagem 2 %32 HTC Flyer MicroUSB Port Replacement: passo 8, imagem 3 %32
      • Wedge the flat end of a spudger inbetween the battery and the front panel assembly.
      • Run the flat end of a spudger along the top edge of the battery to separate it from the adhesive securing it to the front panel assembly.
      • If you encounter any resistance from the remaining adhesive, simply use the flat end of a spudger to remove the excess adhesive.
      Pergunte ao FixBot
      Comentar
    1. HTC Flyer MicroUSB Port Replacement, MicroUSB Port: passo 9, imagem 1 %32
      • Use a spudger to unclip the the wires attached to the power jack
      • The clips have a white or black relief tab that, when pressed, releases the wires.
      Pergunte ao FixBot
      Comentar
    2. HTC Flyer MicroUSB Port Replacement: passo 10, imagem 1 %32 HTC Flyer MicroUSB Port Replacement: passo 10, imagem 2 %32
      • Remove the two 2.5mm Torx T5 screws from both sides of the power jack panel.
      Pergunte ao FixBot
      Comentar
    3. HTC Flyer MicroUSB Port Replacement: passo 11, imagem 1 %32 HTC Flyer MicroUSB Port Replacement: passo 11, imagem 2 %32
      • Gently remove the power jack panel.
      Pergunte ao FixBot
      Comentar
Conclusão
4 outras pessoas executaram este guia.
Joshua
Membro desde: 10/07/14
185 Reputação
Autoria de 1 guia
Equipe
USF Tampa, Team 8-5, Leahy Fall 2014 Membro de USF Tampa, Team 8-5, Leahy Fall 2014
USFT-LEAHY-F14S8G5
3 Membros
Autoria de 12 guias
0Comentários do guia
Comentar
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 6
Últimos 30 dias: 33
Ao todo: 1,539
