Ir para o conteúdo principal
HTC Flyer Headphone Jack Replacement
O que você precisa
  1. HTC Flyer Headphone Jack Replacement, Back Cover: passo 1, imagem 1 %32 HTC Flyer Headphone Jack Replacement, Back Cover: passo 1, imagem 2 %32 HTC Flyer Headphone Jack Replacement, Back Cover: passo 1, imagem 3 %32
    • Apply pressure along the bottom of the white panel containing the camera and push upwards.
    • It may take some effort, but it will smoothly slide off.
    Pergunte ao FixBot
    Comentar
  2. HTC Flyer Headphone Jack Replacement: passo 2, imagem 1 %32 HTC Flyer Headphone Jack Replacement: passo 2, imagem 2 %32 HTC Flyer Headphone Jack Replacement: passo 2, imagem 3 %32
    • Unscrew the four of 3.5mm Torx T5 screws that run along the sides of the exposed innards.
    • All screws in the device will use the Torx T5 screwdriver, so keep it handy.
    Pergunte ao FixBot
    Comentar
  3. HTC Flyer Headphone Jack Replacement: passo 3, imagem 1 %32 HTC Flyer Headphone Jack Replacement: passo 3, imagem 2 %32 HTC Flyer Headphone Jack Replacement: passo 3, imagem 3 %32
    • Remove the black protective piece of plastic by sliding it upwards.
    • Remove the two 3.5mm Torx #5 screws holding the protective plastic down on along the sides.
    • A center 3.5mm Torx screw will be covered by "VOID" sticker.
    • Either remove the sticker or jam the screwdriver into the screw, and remove the screw.
    • Remove the protective panel by sliding it upwards.
    Pergunte ao FixBot
    Comentar
  4. HTC Flyer Headphone Jack Replacement: passo 4, imagem 1 %32 HTC Flyer Headphone Jack Replacement: passo 4, imagem 2 %32
    • Before removing the back cover, apply some scotch tape to the volume buttons to prevent them from falling out of the back panel.
    • Use a plastic opening tool to lever up the top half of the cover.
    • Lift the back panel up and remove it from the device.
    Pergunte ao FixBot
    Comentar
  5. HTC Flyer Headphone Jack Replacement, Battery: passo 5, imagem 1 %32 HTC Flyer Headphone Jack Replacement, Battery: passo 5, imagem 2 %32
    • Gently unfold the black tape along the top that covers the cable attachment points.
    • Leave the tape partially attached so that it can be easily re-attached.
    Pergunte ao FixBot
    Comentar
  6. HTC Flyer Headphone Jack Replacement: passo 6, imagem 1 %32 HTC Flyer Headphone Jack Replacement: passo 6, imagem 2 %32 HTC Flyer Headphone Jack Replacement: passo 6, imagem 3 %32
    • Use the tip of a spudger as a lever to disconnect the four cable connectors.
    • Gently pull out these cables after releasing the back piece.
    Pergunte ao FixBot
    Comentar
  7. HTC Flyer Headphone Jack Replacement: passo 7, imagem 1 %32
    • Remove the single 2.5mm Torx T5 screw holding the battery down along the top side.
    Pergunte ao FixBot
    Comentar
  8. HTC Flyer Headphone Jack Replacement: passo 8, imagem 1 %32 HTC Flyer Headphone Jack Replacement: passo 8, imagem 2 %32 HTC Flyer Headphone Jack Replacement: passo 8, imagem 3 %32
    • Wedge the flat end of a spudger inbetween the battery and the front panel assembly.
    • Run the flat end of a spudger along the top edge of the battery to separate it from the adhesive securing it to the front panel assembly.
    • If you encounter any resistance from the remaining adhesive, simply use the flat end of a spudger to remove the excess adhesive.
    Pergunte ao FixBot
    Comentar
  9. HTC Flyer Headphone Jack Replacement, Motherboard: passo 9, imagem 1 %32 HTC Flyer Headphone Jack Replacement, Motherboard: passo 9, imagem 2 %32
    • Remove the four 2.5mm Torx #5 screws that run along the motherboard's rim.
    Pergunte ao FixBot
    Comentar
  10. HTC Flyer Headphone Jack Replacement: passo 10, imagem 1 %32
    • Use a spudger to remove the two black ground wires from the right side of the motherboard.
    • Remove the two multicolored speaker cables on the right side by lifting up the "lever" on the opposite side of the cable socket and then pulling out the cables.
    Pergunte ao FixBot
    Comentar
  11. HTC Flyer Headphone Jack Replacement: passo 11, imagem 1 %32 HTC Flyer Headphone Jack Replacement: passo 11, imagem 2 %32
    • Lift up the translucent yellow tape to expose the cable sockets.
    • Use the spudger to lift up the cable's "lever".
    • Pull out the cables.
    Pergunte ao FixBot
    Comentar
  12. HTC Flyer Headphone Jack Replacement: passo 12, imagem 1 %32 HTC Flyer Headphone Jack Replacement: passo 12, imagem 2 %32
    • Remove the cable along the headphone in the same way the lower cables were removed.
    Pergunte ao FixBot
    Comentar
  13. HTC Flyer Headphone Jack Replacement: passo 13, imagem 1 %32
    • Grip the motherboard by its edges and pull it out.
    Pergunte ao FixBot
    Comentar
  14. HTC Flyer Headphone Jack Replacement, Headphone Jack: passo 14, imagem 1 %32 HTC Flyer Headphone Jack Replacement, Headphone Jack: passo 14, imagem 2 %32
    • Remove the single 2.5mm Torx T5 screw.
    Pergunte ao FixBot
    Comentar
Conclusão
Justin Funk
Membro desde: 10/07/14
485 Reputação
Autoria de 3 guias
Equipe
USF Tampa, Team 8-5, Leahy Fall 2014 Membro de USF Tampa, Team 8-5, Leahy Fall 2014
USFT-LEAHY-F14S8G5
3 Membros
Autoria de 12 guias
0Comentários do guia
Comentar
Visualizações:
Últimas 24 horas: 1
Últimos 7 dias: 9
Últimos 30 dias: 30
Ao todo: 555
