Ir para o conteúdo principal
HTC Excalibur Keyboard Replacement
O que você precisa
  1. HTC Excalibur Keyboard Replacement, Motherboard: passo 1, imagem 1 %32
    • Remove the rubber screw covers. If needed, use a thin object to help pry them off. There should be two of them on top of the phone. Skip this step if already removed.
    • Pry loose the metal cover near the camera lens.
    Pergunte ao FixBot
    Comentar
  2. HTC Excalibur Keyboard Replacement: passo 2, imagem 1 %32
    • Remove the battery cover.
    • Gripping the battery by the bottom, lift and remove it from the phone.
    Pergunte ao FixBot
    Comentar
  3. HTC Excalibur Keyboard Replacement: passo 3, imagem 1 %32 HTC Excalibur Keyboard Replacement: passo 3, imagem 2 %32 HTC Excalibur Keyboard Replacement: passo 3, imagem 3 %32
    • After removing the rubber stoppers on top, there should be six exposed screws. Remove these using the T6 screwdriver.
    • Next, use the spudger to loosen the case underneath the shiny metal edge. Go all the way around the phone until completely loosened.
    • The case is superglued on and will not permanently damage the phone when removed, but you should still use caution.
    • After loosening the case, remove it.
    • There is a wire that connects both the top and bottom of the case. If you are not careful when removing the case, you might snap the wire.
    Pergunte ao FixBot
    Comentar
  4. HTC Excalibur Keyboard Replacement: passo 4, imagem 1 %32 HTC Excalibur Keyboard Replacement: passo 4, imagem 2 %32
    • Remove the one remaining screw in the logic board.
    • Unclip the wire that connects the back of the case to the logic board.
    Pergunte ao FixBot
    Comentar
  5. HTC Excalibur Keyboard Replacement: passo 5, imagem 1 %32 HTC Excalibur Keyboard Replacement: passo 5, imagem 2 %32 HTC Excalibur Keyboard Replacement: passo 5, imagem 3 %32
    • On the left side of the phone, there are three copper colored clips.
    • Unclip the bottom clip, thread the middle one through the logic board, and pull the top one out gently.
    • You can then lift the logic board out of the phone.
    • Do this at an angle, lifting the side to the right of the SIM card instructions.
    • One of the strips is attached to the front of the case, and goes through the logic board. Be careful not to break this piece.
    Pergunte ao FixBot
    Comentar
  6. HTC Excalibur Keyboard Replacement, Keyboard: passo 6, imagem 1 %32
    • Slip out the copper clips attached to the bottom frame
    • Remove the metal frame carefully.
    Pergunte ao FixBot
    Comentar
  7. HTC Excalibur Keyboard Replacement: passo 7, imagem 1 %32 HTC Excalibur Keyboard Replacement: passo 7, imagem 2 %32 HTC Excalibur Keyboard Replacement: passo 7, imagem 3 %32
    • Use the Phillip 00 screwdriver to remove the 3 screws.
    • After the screws are removed, remove the metal backing to the keyboard.
    • Peel off the keyboard and replace it with a new one
    • After the keyboard is replaced, re-attach the metal backing to the keyboard and re-insert the 3 screws
    Pergunte ao FixBot
    Comentar
Conclusão
Ian Mitchell
Membro desde: 04/19/11
142 Reputação
Autoria de 5 guias
Equipe
Cal Poly, Team 25-27, Garner Spring 2011 Membro de Cal Poly, Team 25-27, Garner Spring 2011
CPSU-GARNER-S11S25G27
4 Membros
Autoria de 10 guias
0Comentários do guia
Comentar
Visualizações:
Últimas 24 horas: 2
Últimos 7 dias: 18
Últimos 30 dias: 39
Ao todo: 2,284
