O que você precisa
Find a seam in the back of the device.
Insert the plastic spudger into the seam and pry off the back panel.
Use a T5 Torx screwdriver to remove the two 4.0 mm screws in the bottom corners of the device.
Use a pair of tweezers to unhook the locks on both sides of the speaker.
Grab the speaker with the tweezers and lift vertically to remove.
Quase terminado!
Conclusão
